Need Suggestion for NS0-513 Exam Preparation Study Material
LamRoy
For me it’s a default task to attempt NS0-513 exam but now I strongly make my mind to attempt it, I want to pass my exam in first attempt, I am looking some worthily study material for preparation, anyone here who pass this exam and tell me for this material which helps you pass this exam?
elizabethmanee
I have recently passed my exam CIW User Interface Designer by using CIW 1D0-621 Braindumps. i cannot express adequately how much helpful this guide has been during my preparation. i say thanks for the instructions and guidelines given by experts on realexamdumps.com. it become possible on with this extraordinary material that i got a fir grip over the field, my approach was refined by providing me a deep understanding and the facts about the practical work within the field. 1D0-621 Dumps gave me knowledge and confidence and online practice test polished my abilities and enhanced my performance.
Malone
The new 2018 version (Oct/2018 Updated) NS0-513 dumps now are available, here are part of NS0-513 exam questions (FYI):
How are the FC-VI links cabled in MetroCluster for ONTAP?
A. one cable to each of the two local FC switches
B. controller A is cabled to FC switch A, controller B has both cabled to FC switch B
C. directly to the corresponding local HA partner
D. directly to the corresponding remote HA partner
You are upgrading your Data ONTAP cluster from clustered Data ONTAP 8.3 to clustered Data ONTAP 9.1. Which two actions must be performed for the SnapMirror relationships? (Choose two.)
A. Break existing SnapMirror relationships.
B. Delete the obsolete SnapMirror Snapshot copies which were created in Data ONTAP 8.3.
C. After the upgrade, resynchronize, and resume SnapMirror relationships.
D. Delete and re-create SnapMirror relationships.
What are two capabilities enabled by Snapshot copies? (Choose two.)
A. Change the volume language of a secondary Snapshot copy.
B. Recover previous versions of a file that was deleted.
C. Write to the Snapshot copy.
D. Create a clone of a FlexVol volume.
Your disaster recovery strategy requires a mirror, an archive, and a tape backup. Which software would you recommend for this scenario?
A. OnCommand System Manager
B. OnCommand Workflow Automation
C. SnapProtect
D. OnCommand Unified Manager
You are performing a routine health check for a customer and need to determine if the disk shelf firmware is up to date. From My AutoSupport, which report would you use?
A. Transition Advisor
B. Visualization
C. Upgrade Advisor
D. Event Viewer
A volume has been filled completely by active data and Snapshot copies. What must you do to make the volume writable again?
A. Delete files in the active file system.
B. Delete any SnapMirror relationships.
C. Delete enough Snapshot copies until space is available.
D. Modify the Snapshot reserve.
Which two NetApp products reduce the backup time and create a consistent backup for a primary Oracle target? (Choose two.)
A. SnapMirror for Open Systems
B. Open Systems SnapVault
C. SnapManager for Orade
D. SnapProtect
Answer: CD
A customer wants compression enabled on the SnapVault secondary volume. Which two statements are true? (Choose two.)
A. A warning message is not displayed when you enable compression on a SnapVault secondary volume.
B. Data transfers will be storage efficient after enabling compression on the SnapVault secondary volume.
C. A warning message is displayed when you enable compression on a SnapVault secondary volume.
D. Data transfers will not be storage efficient after enabling compression on the SnapVault secondary volume.
Answer: CD
The primary and secondary clusters are fully configured. You want to set up an inter-cluster SnapMirror relationship. Which two actions are prerequisite to accomplishing this task? (Choose two.)
A. The SVMs must be peered.
B. The primary and secondary clusters must be peered.
C. The Snapshot schedule must be configured.
D. NDMP must be enabled.
You and other administrators are in the habit of creating FlexClone LUNs and then not deleting them when they are no longer needed. What should you do to help manage space utilization?
A. Use the flexclone split command.
B. Use the volume snapshot autodelete modify command.
C. Configure FlexClone LUNs to automatically be marked for deletion.
D. Configure FlexClone LUNs to automatically delete when they are one minute older than 30 days.
You want to find an automated way to handle space utilization in volumes. You have limited space available in your aggregate. Which solution would solve this scenario?
A. Enable aggregate compression.
B. Enable volume autosize.
C. Enable volume level QoS.
D. Enable Snapshot autodelete.
Which attribute does Data ONTAP use the identify Snapshot copies between primary and secondary FlexVol volumes in a SnapVault relationship?
A. FlexVol name
B. Snapshot prefix
C. SnapMirror policy
D. SnapMirror label
NEW QUESTION 13
You want to provide your team with a SnapProtect report that shows how many backups succeeded, were delayed, and failed over the last 30 days. You also want detailed information about the jobs, agents, and clients. Which CommCell report provides the necessary information?
A. Backup Job Summary
B. Activity
C. Health
D. SLA
NEW QUESTION 14
A customer wants to convert some SnapMirror relationships to SnapVault relationships. How would this be accomplished without creating a new baseline?
A. Break and delete the relationship followed by SnapMirror resync.
B. Break the relationship followed by SnapMirror delete.
C. Break and delete the relationship followed by SnapMirror resync with relationship type XDP.
D. Break the relationship followed by SnapMirror modify.
NEW QUESTION 15
In which two scenarios would a SnapMirror policy be applied? (Choose two.)
A. a log file
B. a storage virtual machine
C. a data protection mirror relationship
D. a SnapVault relationship
Answer: CD
NEW QUESTION 16
Get the newest forbiden NS0-513 VCE dumps here: https://www.forbiden.com/ns0-513.html
Download more NEW forbiden NS0-513 PDF dumps from Google Drive here:
https://drive.google.com/open?id=1c1RUoxiqiEAVHbu5zxj2hnFKIKE7aYif
Read the newest forbiden NS0-513 exam questions from this Blog:
http://www.netappbraindumps.com/?s=NS0-513
