New 70-741 Dumps With VCE and PDF for Passing '2019 70-741 Exam
Hector Garrity
ATTENTION PLEASE!!! THE 70-741 EXAM UPDATED RECENTLY (Mar/2019) WITH MANY NEW QUESTIONS!!!
And, Pass Leader has updated its 70-741 dumps recently, all new questions available now!!!
249Q NEW Version!!!
You can get the newest Pass Leader 70-741 exam questions in the
#11 of this thread!!!
ATTENTION PLEASE!!! THE 70-741 EXAM UPDATED RECENTLY (Oct/2018) WITH MANY NEW QUESTIONS!!!
#9 of this topic!!!
--> #9 of this topic
ATTENTION PLEASE!!! THE 70-741 EXAM UPDATED RECENTLY (Aug/2018) WITH MANY NEW QUESTIONS!!!
#2 of this topic!!!
--> #2 of this topic
The new 70-741 dumps (Dec/2017 Updated) now are available, here are part of 70-741 exam questions (FYI):
NEW QUESTION 123
You have a server named Server1 that runs Windows Server 2016. Server1 has the DHCP Server and the Windows Deployment Service server roles installed. Server1 is located on the same subnet as client computers. You need to ensure that clients can perform a PXE boot from Server1. Which two IPv4 options should you configure in DHCP? (Each correct answer presents part of the solution. Choose two.)
A. 003 Router
B. 066 Boot Server Host Name
C. 015 DNS Domain Name
D. 006 DNS Servers
E. 060 Option 60
NEW QUESTION 124
You network contains an Active Directory domain named contoso.com. The domain contains a member server named Server1 that runs Windows Server 2016 and has the DNS Server role installed. Automatic scavenging of state records is enabled and the scavenging period is set to 10 days. All client computers dynamically register their names in the contoso.com DNS zone on Server1. You discover that the names of multiple client computers that were removed from the network several weeks ago can still be resolved. You need to configure Server1 to automatically remove the records of the client computers that have been offline for more than 10 days.
Solution: You set the Expires after value of the zone.
NEW QUESTION 125
You have an IP Address Management (IPAM) server named IPAM1 that runs Windows Server 2016. IPAM1 manages 10 DHCP servers. You need to provide a user with the ability to track which clients receive which IP addresses from DHCP. The solution must minimize administrative privileges.
A. IPAM MSM Administrators
B. IPAM ASM Administrators
C. IPAM IP Audit Administrators
D. IPAM User
NEW QUESTION 126
You are implementing a new network. The network contains a DHCP server named DHCP1 that runs Windows Server 2016. DHCP1 contains a scope named Scope1 for the 192.168.0/24 subnet. Your company has the following policy for allocating IP addresses:
  • All server addresses must be excluded from DHCP scopes.
  • All client computer must receive IP addresses from Scope1.
  • All Windows servers must have IP addresses in the range of 192.168.0.200 to 192.168.0.240.
  • All other network devices must have IP addresses in the range of 192.168.0.180 to 192.168.0.199.
You deploy a print device named Print1. You need to ensure that Print1 adheres to the policy for allocating IP addresses. Which command should you use?
A. Add-DhcpServerv4Lease
B. Add-DhcpServerv4ExclusionRange
C. Add-DhcpServerv4Filter
D. Add-DhcpServerv4Reservation
NEW QUESTION 127
You have an Active Directory forest that contains 30 servers and 6,000 Client computers. You deploy a new DHCP server that runs Windows Server 2016. You need to retrieve the list of the authorized DHCP servers. Which command should you run?
A. Get-DHCPServerDatabase
B. Netstat -p IP -s -a
C. Get-DHCPServerInDc
D. Show-ADAuthenticationPolicyExpression-AllowedToAuthenticateTo
To get all authorized DHCP servers in Active Directory, you can use the following PowerShell cmdlet: Get-DhcpServerinDC.
NEW QUESTION 128
You have a DHCP server named Server1. Server1 has an IPv4 scope that contains 100 addresses for a subnet named Subnet! Subnet1 provides guest access to the Internet. There are never more than 20 client computers on Subnet1 simultaneously; however, the computers that connect to Subnet 1 are rarely the same computers. You discover that some client computers are unable to access the network. The computers that have the issue have IP addresses in the range of 169.254.0.0/16. You need to ensure that all of the computers can connect successfully to the network to access the Internet. What should you do?
A. Create a new scope that uses IP addresses in the range of 169.254.0.0/16.
B. Modify the scope options.
C. Modify the lease duration.
D. Configure Network Access Protection (NAP) integration on the existing scope.
NEW QUESTION 129
You have a Hyper-V server named Server1 that runs Windows Server 2016. Server1 has an IP address of 192.168.1.78. Server1 has a container named Container1 that hosts a web application on port 84. Container1 has an IP address of 172.16.5.6. Container1 has a port mapping from port 80 on Server1 to port 84 on Container1. You have a server named Server2 that has an IP address of 192.168.1.79. You need to connect to the web application from Server2. To which IP address and port should you connect?
A. 172.16.5.6:80
B. 192.168.1.78:80
C. 172.16.5.6:84
D. 192.168.1.78:84
NEW QUESTION 130
You have a remote access server named Server1 that runs Windows Server 2016. Server1 has DirectAccess enabled. You have a proxy server named Server2. All computers on the internal network connect to the Internet by using the proxy. On Server1, you run the command Set-DAClient -forceTunnel Enabled. You need to ensure that when a DirectAccess client connects to the network, the client accesses all the Internet resources through the proxy. What should you run on Server1?
A. Set-DnsClientGlobalSetting
B. Set-DAEntryPoint
C. Set-DnsClientNrptRule
D. Set-DnsClientNrptGlobal
NEW QUESTION 131
You have an IP Address Management (IPAM) deployment that is used to manage all of the DNS servers on your network. IPAM is configured to use Group Policy provisioning. You discover that a user adds a new mail exchanger (MX) record to one of the DNS zones. You want to identify which user added the record. You open Event Catalog on an IPAM server, and you discover that the most recent event occurred yesterday. You need to ensure that the operational events in the event catalog are never older than one hour. What should you do?
A. From the properties on the DNS zone, modify the refresh interval.
B. From an IPAM_DNS Group Policy object (GPO), modify the Group Policy refresh interval.
C. From Task Scheduler, modify the Microsoft\Windows\IPAM\Audit task.
D. From Task Scheduler, create a scheduled task that runs the Update-IpamServer cmdlet.
NEW QUESTION 132
You have a DHCP server named Server1. Server1 has an IPv4 scope that serves 75 client computers that run Windows 10. When you review the address leases in the DHCP console, you discover several leases for devices that you do not recognize. You need to ensure that only the 75 Windows 10 computers can obtain a lease from the scope. What should you do?
A. Run the Add-DhcpServerv4ExclusionRange cmdlet.
B. Create and enable a DHCP filter.
C. Create a DHCP policy for the scope.
D. Run the Add-DhcpServerv4OptionDefinition cmdlet.
NEW QUESTION 133
Download more NEW Pass Leader 70-741 PDF dumps from Google Drive here:
https://drive.google.com/open?id=0B-ob6L_QjGLpRUl1Y0xaTTdfTjQ
Read the newest Pass Leader 70-741 exam questions from this Blog:
http://www.microsoftbraindumps.com/?s=70-741
Hector Garrity
The new 70-741 dumps (Aug/2018 Updated) now are available, here are part of 70-741 exam questions (FYI):
NEW QUESTION 189
You have Hyper-V host named Server1. Serve1 has a network adapter that has virtual machine queue (VMQ) enabled. The network adapter connects at 10 Gbps and has an IPv4 address. Server1 hosts a virtual machine named VM1. VM1 has a single network adapter and four processors. You need to distribute the network processing load across the VM1 processors. What should you do?
A. From Device Manager on Server1, configure TCP Checksum Offload (IPv4).
B. From Windows PowerShell on VM1, run the Enable-NetAdapterRSS cmdlet.
C. From Windows PowerShell on Server1, run the Enable-NetAdapterPacketDirect cmdlet.
D. From Windows PowerShell on VM1, run the Enable-NetAdapterPacketDirect cmdlet.
NEW QUESTION 190
Your network contains an Active Directory domain named contoso.com. The domain contains a Hyper-V host. You are deploying Software Defined Network (SDN) by using Windows Server 2016. You deploy a virtual machine that runs Windows Server 2016, and you install the Network Controller server role. You need to configure the virtual machine as the network controller. What should you do?
A. Run the Install-NetworkControllerCluster cmdlet and set ClientAuthentication to X509.
B. Run the Install-NetworkController cmdlet and set ClientAuthentication to None.
C. Run the Install-NetworkControllerCluster cmdlet and set ClientAuthentication to None.
D. Run the Install-NetworkController cmdlet and set ClientAuthentication to Kerberos.
NEW QUESTION 191
Your company has five departments, including a web research department. You have a DHCP server named Server1 and two DNS servers named DNS1 and DNS2. Server1 has an IPv4 scope named Scope1. All client computers are configured to use DNS1 for name resolution. You need to ensure that users in the web research department use DNS2 for name resolution. What should you do on Server1?
A. From the properties of Scope1, modify the Conflict detection attempts setting.
B. From the properties of Scope1, configure Name Protection.
C. From the properties of IPv4, configure the bindings.
D. From IPv4, create a new filter.
E. From the properties of Scope1, create an exclusion range.
F. From IPv4, run the DHCP Policy Configuration Wizard.
G. From Control Panel, modify the properties of Ethernet.
H. From Scope1, create a reservation.
NEW QUESTION 192
You have an IP Address Management (IPAM) server named Server1 that runs Windows Server 2016. You have five DHCP servers. Server1 manages all of the DHCP servers. On Server1, an administrator uses Purge Event Catalog Data to remove all of the events from the last 30 days. You need to view all of these lease requests that were denied during the last two days. What should you do?
A. On each DHCP server, run the \Microsoft\Windows\Server Manager\CleanUpOldPerfLogs scheduled task, and then review the event catalog on Server1.
B. On Server1, run the Purge Event Catalog Data action and then open Event Viewer on Server1.
C. Review the log data in C:\Windows\System32\ipam\Database on Server1.
D. On each DHCP server, review the DHCP Server operational event log.
NEW QUESTION 193
You have a server named Server1 that runs Windows Server 2016. Server1 is an IP Address Management (IPAM) server that collects DHCP and DNS logs and events for your entire network. You need to get the IP addresses that were assigned to a client computer named Computer1 during the last week. What should you do on Server1?
A. Open Event Viewer and click Windows Logs. Filter the Forwarded Events log for Computer1.
B. Open Event Viewer and click Windows Logs. Filter the Security log for Computer1.
C. Run the Get-IpamAddress cmdlet.
D. Run the Get-IpamIpAddressAuditEvent cmdlet.
NEW QUESTION 194
You are implementing a secure network. The network contains a DHCP server named Server1 that runs Windows Server 2016. You create a DHCP allow filter that contains all of the computers on the network that are authorized to receive IP addresses. You discover that unauthorized computers can receive an IP address from Server1. You need to ensure that only authorized computers can receive an IP address from Server1.
Solution: You run the following command:
Set-DhcpServerv4FilterList –ComputerName Server1 –Allow False –Deny True
NEW QUESTION 195
Add-DHCPServer4Filter –ComputerName Server1 –MacAddress * -List Allow
NEW QUESTION 196
Add-DHCPServer4Filter –ComputerName Server1 –MacAddress * -List Deny
NEW QUESTION 197
You have an IP Address Management (IPAM) server named IPAM1 that runs Windows Server 2016. IPAM1 manages all of the DHCP servers on your network. You are troubleshooting an issue for a client that fails to receive an IP address from DHCP. You need to ensure that from IPAM1, you can view all of the event data for the DHCP leases from the last 24 hours.
Solution: From Windows PowerShell, you run the Invoke-IpamServerProvisioning cmdlet.
NEW QUESTION 198
Solution: From Windows PowerShell, you run the Set-IpamDHCPServer cmdlet.
NEW QUESTION 199
Solution: From Server Manager, you run Retrieve Event Catalog Data.
NEW QUESTION 200
You implement Software Defined Networking (SDN) by using the Network Controller server role. You have a virtual network named VNET1 that contains servers used by developers. You need to ensure that only devices from the 192.168.0.0/24 subnet can access the virtual machine in VNET1. What should you configure?
A. a network security group (NSG)
B. role-based access control
C. a universal security group
D. Dynamic Access Control
NEW QUESTION 201
You have a virtual machine named Server1 that runs Windows Server 2016. You plan to use Server1 as part of a Software Defined Networking (SDN) solution. You need to implement the Border Gateway Protocol (BGP) on Server1. What should you install?
A. the Peer Name Resolution Protocol (PNRP) feature
B. the Routing role service
C. the Network Device Enrollment Service role service
D. the Network Policy and Access Services server role
NEW QUESTION 202
You have a Nano Server that has one network interface. The server is configured to obtain an IP address automatically. You need to configure the server to have the following IP configurations:
  • IP address: 172.16.3.100
  • Default gateway: 172.16.3.1
  • Subnet mask: 255.255.255.0
What command should you run? (To answer, select the appropriate options in the answer area.)
NEW QUESTION 203
You have a server named Server1 that runs Windows Server 2016. You need to deploy the first node cluster of a Network Controller cluster. Which four cmdlets should you run in sequence? (To answer, move the appropriate cmdlets from the list of cmdlets to answer area and arrange them in the correct order.)
NEW QUESTION 204
Vorryn
This forum section is just a huge ad for the respective sites that sell the dumps.
Please stop that. Share the full dumps.
Thank you.
Derk21
Nothing but link pumping and spam on this forum now, sad.
Zaixkingg
The 70-741 study material comes with many latest exam questions and updated answers. If you want to pass the exam with lesser efforts like me, then use 70-741 exam dumps PDF.
Thanks "markalan037", Great Guide to pass the test. Some questions have incorrect answers but overall great guide... This definitely helped me pass my my exam
Hector Garrity
The new 70-741 dumps (Oct/2018 Updated) now are available, here are part of 70-741 exam questions (FYI):
NEW QUESTION 208
You are deploying Software Defined Networking (SDN) by using Windows Server 2016. You plan to deploy a three-node Network Controller cluster. You plan to use virtual machines for the network controller and the management client. The virtual machines will NOT be domain-joined. You need to configure authentication for the cluster. Which command should you run?
A. Install-NetworkController -Node @{Node1, Node2, Node3} -ClientAuthentication X509
B. Install-NetworkControllerCluster -Node @{Node1, Node1, Node3} -ClientAuthentication Kerberos
C. Install-NetworkControllerCluster -Node @{Node1, Node1, Node3} -ClientAuthentication X509
D. Install-NetworkControllerCluster -Node @{Node1, Node1, Node3} -ClientAuthentication None
E. Install-NetworkController -Node @{Node1, Node2, Node3} -ClientAuthentication Kerberos
NEW QUESTION 209
Solution: From Task Scheduler, you run the Microsoft\Windows\IPAM\Audit task.
NEW QUESTION 210
You have a server named Server1 that runs Windows Server 2016. Server1 is configured as a VPN server. Server1 is configured to allow domain users to establish VPN connections from 06:00 to 18:00, every day of the week. You need to ensure that domain users can establish VPN connections only between Monday and Friday.
Solution: From Network Policy Server, you modify the Network Policies on Server1.
NEW QUESTION 211
Your company owns the public Internet IP address range of 131.107.20.0 to 131.107.20.255. You need to create a subnet that supports four hosts. The solution must minimize the number of addresses available to the subnet. Which subnet should you use?
A. 131.107.20.16 with subnet mask 255.255.255.248
B. 131.107.20.16/28
C. 131.107.20.0/27
D. 131.107.20.16/30
NEW QUESTION 212
You have Hyper-V host named Server1. Server1 has a network adapter that has virtual machine queue (VMQ) enabled. The network adapter connects at 10 Gbps and has an IPV4 address. Server1 hosts a virtual machine named VM1. VM1 has a single network adapter and four processors. You need to distribute the network processing load across the VM1 processors. What should you do?
A. From Windows PowerShell on Server1, run the Enable-NetAdapterPacketDirect cmdlet.
B. From Windows PowerShell on VM1, run the Enable-NetAdapterPacketDirect cmdlet.
C. From Device Manager on VM1, configure Receive Side Scaling.
D. From Windows PowerShell on Server1, run the Enable-NetAdapterRSS cmdlet.
NEW QUESTION 213
A. From the IPAM node in Server Manager, click Event Catalog, and then review the IP Address Tracking.
C. Run the Export-IpamAddress cmdlet.
D. From the IPAM node in Server Manager, click IP Address Space, and then review the IP Address Inventory.
E. Run the Get-IpamDhcpConfigurationEvent cmdlet.
NEW QUESTION 214
Your network contains an Active Directory domain named contoso.com. The domain contains two servers named Server1 and Server2 that run Windows Server 2016. Server1 has IP Address Management (IPAM) installed. Server2 has the DHCP Server role installed. The IPAM server retrieves data from Server2. You create a domain user account named User1. You need to ensure that User1 can use IPAM to manage DHCP. Which command should you run on Server1? (To answer, select the appropriate options in the answer area.)
NEW QUESTION 215
You have a remote access server named Server1 that runs Windows Server 2016. Server1 has DirectAccess enabled. You have a proxy server named Server2. All computers on the internet connect to the Internet by using the proxy. On Server1, you run the command Set-DAClient -ForceTunnel Enabled. You need to ensure that when a Direct Access client connects to the network, the client accesses all the Internet resources through the proxy. What should you run on Server1?
A. Set-DAClient
B. Set-DnsClientGlobalSetting
C. Set-DAClientDNSConfiguration
D. Set-DAEntryPoint
NEW QUESTION 216
You have a server named Server1 that runs Windows Server 2016 and is configured as a domain controller. You install the DNS Server server role on Server1. You plan to store a DNS zone in a custom Active Directory partition. You need to create a new Active Directory partition for the zone. What should you use?
A. Set-DnsServer
B. DNS Manager
C. New-ADObject
D. Ntdsutil.exe
E. Active Directory Sites and Services
NEW QUESTION 217
You have a DNS server named Server1 that runs Windows Server 2016. Server1 has two Active Directory-integrated zones named contoso.com and adatum.com. All client computers run Windows 10. Server1 recently experienced millions of erroneous DNS queries causing a denial of service. You need to reduce the likelihood that a similar attack will cause a denial of service. The solution must ensure that Server1 continuous to resolve names for clients. What should you do?
A. Implement DNS-based Authentication of Named Entities (DANE)
B. Enable Response Rate Limiting (RRL) on Server1
C. Configure DNS policies on Server1
D. Sign both adatum.com and contoso.com zones
NEW QUESTION 218
You have a server named Server1 that runs Windows Server 2016. Server1 is in a workgroup and has the DNS Server role installed. You need to enable DNS analytical diagnostic logging on Server1. What should you do?
A. From Local Group Policy Editor, configure Audit Policy.
B. From DNS Manager, configure Monitoring.
C. From Windows PowerShell, run the Enable-DnsServerPolicy cmdlet.
D. From DNS Manager, configure Event Logging.
E. From Event Viewer, configure DNS-Server Applications and Services Logs.
NEW QUESTION 219
You have an IP Address Management (IPAM) server named IPAM1 that runs Windows Server 2016. IPAM1 manages 10 DHCP servers. You need to provide a user with the ability to track which clients receive which IP addresses from DHCP. The solution must minimize administrative privileges. To which group should you add the user?
A. IPAM IP Audit Administrators
C. IPAM MSM Administrators
D. IPAM User
NEW QUESTION 220
You have a Hyper-V host named Host1 that runs Windows Server 2016 Datacenter. Host1 has eight network adapters that support Remote Direct Memory Access (RDMA). You plan to configure Host1 as part of a four-node Hyper-V converged solution. You enable the Data Center Bridging (DCB) feature. You need to enable Switch Embedded Teaming (SET) and RDMA. Which three cmdlets should you run in sequence? (To answer move the appropriate cmdlets from the list of cmdlets to the answer area and arrange them in the correct order.)
NEW QUESTION 221
dumpsprofessor
I have recently passed my IT exam by using 70-741 braindumps. I cannot express adequately how much helpful this guide has been during my preparation. I say thanks for the instructions and guidelines given by the experts on Dumpsprofessor. It became possible on with this extraordinary material that I got a firm grip over the field. My approach was refined by providing me a deep understanding and the facts about the practical work within the field. 70-741 dumps gave me knowledge and confidence and online practice test polished my abilities and enhanced my performance.
Gabriel357
This team is very professional. 70-741 dumps were very informative. Everything was precise and to the point. I would love to do another certification with the help of braindumpscerts.com I am very confident that I am trained by one of the best companies in the market. There efforts are much appreciated. http://bit.ly/Microsoft-70-741-Dumps-PDF
Ronaldo Civiq
For me, it was impossible to get Networking with Windows Server 2016 with its enigmatic nature due to unavailability of a proper study material. But I owe deep and sincere thanks to Dumps4Download.com for offering 70-741 Dumps PDF. Now I am so excited after my exceptional result with this study guide. I recommend this guide book to everyone going to appear in this IT certification.
proeasyweb
I have as of late passed my IT test by utilizing 70-741 Dumps PDF. I can't express sufficiently how much supportive this guide has been amid my planning. I express profound gratitude for the directions and rules given by the specialists on RealExamCollection.com. It wound up conceivable on with this remarkable material that I got a firm grasp over the field. My methodology was refined by giving me a profound comprehension and the realities about the down to earth work inside the field. 70-741 dumps gave me learning and certainty and online practice test cleaned my capacities and improved my execution.
Hector Garrity
The new 70-741 dumps (Mar/2019 Updated) now are available, here are part of 70-741 exam questions (FYI):
NEW QUESTION 234
You have a Hyper-V host named Server 1. The network adapters on Server1 have single root I/O virtualization (SR-IOV) enabled. Server1 hosts a virtual machine named VM1 that runs Windows Server 2016. You need to identify whether SR-IOV is used by VM1.
Solution: You sign in to VM1. You run the Get-NetAdapterSriov cmdlet.
NEW QUESTION 235
Solution: You sign in to VM1. You view the properties of the network connections.
NEW QUESTION 236
Solution: On Server1, you open Hyper-V Manager and view the Integration Services settings of VM1.
NEW QUESTION 237
Solution: You sign in to VM1. You open Device Manager and view the properties of the network adapters.
NEW QUESTION 238
Your network contains an Active Directory domain named contoso.com. The domain contains a server named Server2 that runs Windows Server 2016. The DHCP Server server role is installed on Server2. The DNS server role is installed on a server named Server3. The network contains 500 non-Windows devices that are registered in the DNS zone of contoso.com. You configure Server2 to lease IP addresses to the non-Windows devices. You need to prevent Server2 from overwriting the host (A) records for the non-Windows devices. What should you run?
A. dism.exe
B. dns.exe
C. dnscmd.exe
D. netsh.exe
E. Set-DhcpServerDatabase
F. Set-DhcpServerv4DnsSetting
G. Set-DhcpServerv6DnsSetting
H. Set-DNSServerSetting
NEW QUESTION 239
You have a server named Server1 that runs Windows Server 2016. Server1 is an IP Address Management (IPAM) server that collects DHCP and DNS logs and events for your entire network. You need to enable a user named TECH1 to create pointer (PTR), host (A) and service location (SRV) records on all of the DNS servers on the network. What should you do on Server1?
A. Run the Set-IpamRange cmdlet, and then run the Set-IpamAddressSpace cmdlet.
B. Run the Set-IpamCustomField cmdlet, and then run the Set-IpamAccessScope cmdlet.
C. From the IPAM node in Server Manager, assign the IPAM DNS Administrator Role to TECH1 and create a new access policy.
D. From the IPAM node in Server Manager, assign the IPAM DNS Administrator Role to TECH1 and create a new access scope.
NEW QUESTION 240
You have a server named Server1 that has a Server Core installation of Windows Server 2016. Server1 is configured to obtain an IP address automatically. You need to configure the IPv4 address, netmask, and default gateway manually for a network interface named Ethernet on Server1. What should you run?
A. ipconfig.exe
B. New-NetIPAddress
C. Set-NetAdapter
D. Set-NetIPv4Protocol
NEW QUESTION 241
Your network contains an Active Directory domain named contoso.com. The domain contains two servers named Server1 and Server2 that run Windows Server 2016. Server1 has IP Address Management (IPAM) installed. Server2 has Microsoft System Center 2016 Virtual Machine Manager (VMM) installed. You need to integrate IPAM and VMM. Which types of objects should you create on each server? (To answer, drag the appropriate object types to the correct servers. Each object type may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.)
NEW QUESTION 242
You use a Network Policy Server (NPS) server named NPS1 to authenticate VPN connections and connections to wireless access points (WAPs). You plan to add a new WAP named WAP1. What should you do on WAP1 and NPS1? (To answer, select the appropriate options in the answer area.)
NEW QUESTION 243
A. Set-DnsServer
B. Dns.exe
C. Ntdsutil.exe
D. Active Directory Administrative Center
NEW QUESTION 244
You are deploying a small network that has 30 client computers. The network uses the 192.168.1.0/24 address space. All computers obtain IP configurations from a DHCP server named Server1. You install a server named Server2 that runs Windows Server 2016. Server2 has two network adapters named Internal and Internet. Internet connects to an Internet Service Provider (ISP) and obtains the 131.107.0.10 IP address. Internal connects to the internal network and is configured to use the 192.168.1.250 IP address. You need to provide Internet connectivity for the client computers. What should you do?
A. On Server2, select the Internet and Internal network adapters and bridge the connections.
From the DHCP console on Server1, authorize Server2.
B. On Server2 run the New-NetNat -Name NAT1 -InternalIPInterfaceAddressPrefix 192.168.1.0/24 cmdlet. Configure Server1 to provide the 003 Router option of 131.107.0.10.
C. On Server1, stop the DHCP server.
On the Internet adapter on Server2, enable internet Connection Sharing (ICS).
D. Recreate the DHCP scope on Server1 to lease addresses from the 131.107.0.0/24 address space.
On Server2, change the IP address of the internal network adapter to 131.107.0.1.
Configure Server1 to provide the 003 Router option of 131.107.0.1.
NEW QUESTION 245
You have an Active Directory forest that contains 30 servers and 6,000 client computers. You deploy a new DHCP server that runs Windows Server 2016. You need to retrieve the list of the authorized DHCP servers. Which command should you run?
A. Get-ADResourceProperty -Filter DHCP
B. Netsh DHCP show server
C. Netsh DHCP server initiate auth
D. Get-DHCPServerSetting
NEW QUESTION 246
brackdeen
Passing the 70-741 exam is no more difficult, with latest 70-741 dumps pdf anyone can easily pass the 70-741 exam on the first attempt! The best thing is 100% success rate & money back assurance.
Note:- New Questions has been added to the 70-741 PDF.
Get the complete 70-741 Question Answers PDF & Start preparation:- 70-741 Dumps 2019
https://www.realdumpspdf.com/exam/70-741-dumps-pdf/
Product Features:
1) 100% Success Rate
2) Money Back Assurance
3) Up-to-date Questions
4) Instant Download
5) Free Updates for 3 months
sophia
Learning material for 70-741 exam offered by braindumpscerts is worth buying. In-depth and relevant knowledge have helped me a lot to perform very well in my exam and also, I scored high on the first attempt. Everything is creatively explained and I got new ideas that how a problem can be solved efficiently. Thanks a lot, to the braindumpscerts team for providing the real exam questions.
Download PDF & Pass Exam on the first attempt!
https://www.braindumpscerts.com/vendors/Microsoft/MCSA/70-741-dumps.php
