New Fortinet NSE7_EFW Dumps with VCE and PDF (Apr/2018 Updated)
Discussion in 'Section Request' started by Jonathan Cheverez, Apr 16, 2018 at 11:02 AM.
  1. Jonathan Cheverez
    Monday
    The new 2018 version (Apr/2018 Updated) NSE7_EFW dumps now are available, here are part of NSE7_EFW exam questions (FYI):
    Four FortiGate devices configured for OSPF connected to the same broadcast domain. The first unit is elected as the designated router. The second unit is elected as the backup designated router Under normal operation, how many OSPF full adjacencies are formed to each of the other two units?
    A. 1
    B. 2
    C. 3
    D. 4
    The logs in a FSSO collector agent (CA) are showing the following error:
    "failed to connect to registry: PIKA1026 (192.168.12.232)"
    What can be the reason for this error?
    A. The CA cannot resolve the name of the workstation.
    B. The FortiGate cannot resolve the name of the workstation.
    C. The remote registry service is not running in the workstation 192.168.12.232.
    D. The CA cannot reach the FortiGate with IP address 192.168.12.232.
    Which the following events can trigger the election of a new primary unit in a HA cluster? (Choose two.)
    A. Primary unit stops sending HA heartbeat keepalives.
    B. The FortiGuard license for the primary unit is updated.
    C. One of the monitored interfaces in the primary unit is disconnected.
    D. A secondary unit is removed from the HA cluster.
    Which statements are correct regarding an IPv6 over IPv4 IPsec configuration? (Choose two.)
    A. The source quick mode selector must be an IPv4 address.
    B. The destination quick mode selector must be an IPv6 address.
    C. The Local Gateway IP must be an IPv4 address.
    D. The remote gateway IP must be an IPv6 address.
    What configuration changes can reduce the memory utilization in a FortiGate? (Choose two.)
    A. Reduce the session time to live.
    B. Increase the TCP session timers.
    C. Increase the FortiGuard cache time to live.
    D. Reduce the maximum file size to inspect.
    An administrator has enabled HA session synchronization in a HA cluster with two members. Which flag is added to a primary unit's session to indicate that it has been synchronized to the secondary unit?
    A. redir
    B. dirty
    C. synced
    D. nds
    When does a RADIUS server send an Access-Challenge packet?
    A. The server does not have the user credentials yet.
    B. The server requires more information from the user, such as the token code for two-factor authentication.
    C. The user credentials are wrong.
    D. The user account is not found in the server.
    Which statements regarding banned words are correct? (Choose two.)
    A. Content is automatically blocked if a single instance of a banned word appears.
    B. The FortiGate updates banned words on a periodic basis.
    C. The FortiGate can scan web pages and email messages for instances of banned words.
    D. Banned words can be expressed as simple text, wildcards and regular expressions.
    Answer: CD
    In which order are firewall policies processed on a FortiGate unit?
    A. From top to down, according with their sequence number.
    B. From top to down, according with their policy ID number.
    C. Based on best match.
    D. Based on the priority value.
    Which real time debug should an administrator enable to troubleshoot RADIUS authentication problems?
    A. diagnose debug application radius -1
    B. daignose debug application fnbamd -1
    C. diagnose authd console-log enable
    D. diagnose radius console-log enable
    Get the newest PassLeader NSE7_EFW VCE dumps here:
    bit.ly/passleader-nse7_efw-dumps
    Download more NEW PassLeader NSE7_EFW PDF dumps from Google Drive here:
    bit.ly/passleader-nse7_efw-dumps-pdf
    Read the newest PassLeader NSE7_EFW exam questions from this Blog:
    bit.ly/online-passleader-nse7_efw-dumps
    (p.s. copy the upper short links and open them in your web browser!!!)
  2. JeroenHermans
    JeroenHermans Member
    Tuesday
    Well Done!!!
    Thanks for sharing helpful PassLeader NSE7_EFW dumps!!!
