passed 410
Discussion in '70-410 Exam files' started by ciscozel, Nov 24, 2015.
  1. ciscozel
    ciscozel Supplier
    Supplier Member
    85
    used leadtopass and examcollection
    the were couple of rephrased questions
    You perform a Server Core Installation of Windows Server 2012 R2 on a server named Serverl. You need to add a graphical user interface (GUI) to Server
    Which tool should you use?
    A. the ocsetup.exe command
    B. the Install-Module cmdlet
    C. the dism.exe command
    D. the setup.cmd command
  2. ciscozel
    ciscozel Supplier
    Supplier Member
    85
    Your network contains one Active Directory domain named contoso.com. The domain contains 10 domain controllers that run Windows Server 2012 R2.
    You need to prevent several members of the Domain Admins group from logging on to the domain controllers. Which two objects should you create and configure? Each correct answer presents part of the solution.
    ❑ A. a user certificate
    O B. a Group Policy object (GPO) linked to the domain
    ❑ C. a central access policy
    D. an authentication policy
    ❑ E. an authentication policy silo
  3. jbbastos
    jbbastos Member
    Nov 4, 2015
    Congratulations bro do you have the answers for this questions?
  • Trystar1
    Trystar1 Member
    Nov 9, 2015
    Congratulation ciscozel ! I'd be taking that exam in a week.
  • shaker007
    shaker007 Member
    Nov 20, 2015
    D and E is the correct answer
