Passed AZ-900 exam with high score
wirygnrhd
I just passed my AZ-900 exam with high score. I studied the following Microsoft AZ-900 exam dump questions.
This question requires that you evaluate the underlined text to determine if it is correct.Azure Germany can be used by legal residents of Germany only.Instructions: Review the underlined text. If it makes the statement correct, select “No change is needed”. If the statement is incorrect, select the answer choice that makes the statement correct.
A. no change is needed
B. only enterprises that are registered in Germany
C. only enterprises that purchase their azure licenses from a partner based in Germany
D. any user or enterprise that requires its data to reside in Germany
Your company plans to automate the deployment of servers to Azure. Your manager is concerned that you may expose administrative credentials during the deployment. You need to recommend an Azure solution that encrypts the administrative credentials during the deployment.What should you include in the recommendation?
A. Azure Key Vault
B. Azure Information Protection
C. Azure Security Center
D. Azure Multi-Factor Authentication (MFA)
If you want to study more AZ-900 exam questions, you can practice AZ-900 questions on the following page.
KellyeImser
TheExamCerts is the best site which provides you with the necessary Microsoft AZ-900 questions that will help you to get the AZ-900 Microsoft Azure Fundamentals exam on the first attempt. The latest questions can be found here and that is the reason why this is the one that you need to use and I can tell you that there is no reason for you to fail when you will have valid Microsoft AZ-900 braindumps from TheExamCerts. They have the guarantee that the Microsoft AZ-900 questions that they have will be the ones that will make you pass your AZ-900 exam in the very first go. You must try our Microsoft AZ-900 free demo befor your successive purchase. Follow this link and get 20% discount offer [Limited Time]:
