Please Help me for some question?
Discussion in '70-414 Exam Files' started by emiort, Dec 21, 2015.
  1. emiort
    emiort Member
    Dec 10, 2015
    29
    PassLeader.Premium QUESTION 72
    In adatum.com, you install and configure a server that has the Active Directory Federation Services server role and all of the AD FS role services installed.
    You need to recommend which AD FS configurations must be performed m adatum.com to meet the security requirements.
    Which configurations should you recommend before creating a trust policy?
    A. Export the server authentication certificate and provide the certificate to Trey Research. Import the token-signing certificate from Trey Research.
    B. Export the server authentication certificate and provide the certificate to Trey Research. Import the server authentication certificate from Trey Research.
    C. Export the token-signing certificate and provide the certificate to Trey Research. Import the server authentication certificate from Trey Research. D. Export the token-signing certificate and provide the certificate to Trey Research. Import the token-signing certificate from Trey Research
    Answer B or C ??
    PassLeader.Premium QUESTION 154
    Your network contains an Active Directory domain named contoso.com.
    The domain contains a member server named Server 1.
    Server1 runs Windows Server 2012 R2 and has the Hyper-V server role installed.
    You create an external virtual switch named Switch1.
    Switch1 has the following configurations:
    - Connection type: External network
    - Single-root I/O virtualization (SR-IOV): Enabled
    Ten virtual machines connect to Switch1.
    You need to ensure that all of the virtual machines that connect to Switch1 are isolated from the external network and can connect to each other only.
    The solution must minimize network downtime for the virtual machines.
    A. Remove Switch1 and recreate Switch1 as an internal network.
    B. Change the Connection type of Switch1 to Private network.
    C. Change the Connection type of Switch1 to Internal network.
    D. Remove Switch1 and recreate Switch1 as a private network.
    Answer B or D?
    #1 emiort, Dec 21, 2015
  2. emiort
    emiort Member
    Dec 10, 2015
    29
    PassLeader.Premium QUESTION 177
    ON CLUSTER3, use the Failover Cluster Manager to add a SCSI controller to SQL-SERVER3
    CREATE vhdx HARD DISK
    ENABLE VHD SHARING
    ON CLUSTER1, use the Failover Cluster Manager to add a SCSI controller to VM.SQL-NODE1.contoso.com
    ENABLE VHD SHARING
  3. emiort
    emiort Member
    Dec 10, 2015
    29
    PassLeader.Premium QUESTION 185
    You are an Active Directory administrator for Contoso, Ltd.
    You have a properly configured certification authority (CA) in the contoso.com Active Directory Domain Services (AD DS) domain.
    Contoso employees authenticate to the VPN by using a user certificate issued by the CA.
    Contoso acquires a company named Litware, Inc., and establishes a forest trust between contoso.com and litwareinc.com.
    No CA currently exists in the litwareinc.com AD DS domain.
    Litware employees do not have user accounts in contoso.com and will continue to use their litwareinc.com user accounts.
    Litware employees must be able to access Contoso's VPN and must authenticate by using a user certificate that is issued by Contoso's CA.
    You need to configure cross-forest certificate enrollment for Litware users.
    Which two actions should you perform? Each correct answer presents part of the solution.
    A. Grant the litwareinc.com AD DS Domain Computers group permissions to enroll for the VPN template on the Contoso CA.
    B. Copy the VPN certificate template from contoso.com to litwareinc.com.
    C. Add Contoso's root CA certificate as a trusted root certificate to the Trusted Root Certification Authority in litware.com.
    D. Configure clients in litwareinc.com to use a Certificate Policy server URI that contains the location of Contoso's CA.
    AC or CD??
  4. emiort
    emiort Member
    Dec 10, 2015
    29
    PassLeader.Premium QUESTION 187
    You administer a group of servers that run Windows Server 2012 R2.
    You must install all updates.
    You must report on compliance with the update policy on a monthly basis.
    You need to configure updates and compliance reporting for new devices.
    A. Deploy the Microsoft Baseline Security Analyzer. Scan the servers and specify the /apply switch.
    B. In Configuration Manager, deploy a new Desired Configuration Management baseline that includes all required updates.
    C. Configure a new group policy to install updates monthly. Deploy the group policy to all servers.
    D. In Operations Manager, create an override that enables the software updates management pack. Apply the new override to the servers.
    Answer: B or C
  5. emiort
    emiort Member
    Dec 10, 2015
    29
    PassLeader.Premium QUESTION 231
    You need to deploy the dedicated storage servers to support the new web application servers.
    A. Install windows storage server 2012 R2 workgroup on STORAGE1 and STORAGE2. Use STORAGE 1 and STORAGE2 as scale-out file servers.
    B. Install windows storage server 2012 R2 standard on STORAGE1 and STORAGE2. Use STORAGE1 and STORAGE2 as ISCSI target servers.
    C. Install windows storage server 2012 R2 workgroup on STORAGE1 and STORAGE2.Use STORAGE1 and STORAGE2 as ISCSI target servers.
    D. Install windows storage server 2012 R2 standard on STORAGE1 and STORAGE2. Use STORAGE1 and STORAGE2 as scale-out file server.
    Answer: D or A
  6. emiort
    emiort Member
    Dec 10, 2015
    29
    PassLeader.Premium QUESTION 235
    You need to design a solution that meets the monitoring requirements.
    A. In Service Manager , create an alert routing rule in the Operations Manager Alert connector that created a new incident when the HR application procedure a performance alert.
    B. In service Manager, create a queue that will open a new ticket or close any existing HR application performance ticket when the performance alert has been resolved in Operations Manager.
    C. In Service Manager, create a workflow that will open a new ticket or close any existing HR application performance ticket when the performcance alert has been resolved in Operation Manager.
    D. In Operations Manager, create an override for the HR application monitor that will close any open HR application performance tickets in service manager.
    Answer: A or C
  7. emiort
    emiort Member
    Dec 10, 2015
    29
    PassLeader.Premium QUESTION 238
    You need to prepare the environment for App1.
    Which two actions should you perform? Each correct answer present part of the solution.
    A. Install a new cluster for App1 at the Seattle data center.
    B. Run the following Widows PowerShell cmdlet for each node in the backup data center... Set lowerQuorumPriorityNodeID=1
    C. Install a new cluster for App1 at the Chicago data center.
    D. Run the following Widows PowerShell cmdlet for each node in the backup data center.. Set NodeWeight=1
    Answer: AD or AB
  8. mecbeau
    mecbeau Member
    Nov 2, 2015
    345
    A. Export the server authentication certificate and provide the certificate to Trey Research. Import the token-signing certificate from Trey Research. B. Export the server authentication certificate and provide the certificate to Trey Research. Import the server authentication certificate from Trey Research.
    Answer B or C ??
    Answer B or D?
    C
    D
    respectively
  • mecbeau
    mecbeau Member
    Nov 2, 2015
    345
    ENABLE VHD SHARING
    ENABLE VHD SHARING
    ENABLE VHD SHARING
  • mecbeau
    mecbeau Member
    Nov 2, 2015
    345
    Answer: AD or AB
    ADAnswer: AD
  • mecbeau
    mecbeau Member
    Nov 2, 2015
    345
    Answer: A or C
    C for sure
  • mecbeau
    mecbeau Member
    Nov 2, 2015
    345
    Answer: D or A
  • mecbeau
    mecbeau Member
    Nov 2, 2015
    345
    Answer: B or C
  • mecbeau
    mecbeau Member
    Nov 2, 2015
    345
    AC or CD??
  • emiort
    emiort Member
    Dec 10, 2015
    29
    Correct Answer: A or D?? i think D
  • emiort
    emiort Member
    Dec 10, 2015
    29
    C
    respectively
    are you sure? I THINK "B" Export the server authentication certificate and provide the certificate to Trey Research. Import the server authentication certificate from Trey Research.
    #16 emiort, Dec 22, 2015
  • dapenguin
    dapenguin Member
    Oct 30, 2015
    120
    Would like peoples thoughts here too. I'm leaning with C though.
  • krampolec
    krampolec Member
    Jan 11, 2016
    Q72 : C.
    Q154 : D
    Q177 :
    ENABLE VHD SHARING
    - VHD Sharing is R2 feature, thus Cluster3
    Q185 :
    AC - litwareinc.com doesn't have PKI and CA attributes are replicated in GC => accross trust => litwareinc.com knows where to find contoso's CA.
    Q187 :
    I would go with C . Compliance means SCCM. and there is no WSUS. If there would be
    Q2013
    D - You can not make SOFS without domain.
    Q235
    A - This type of thins is done from Service manager, as there is a connector in Service manager for SCOM.
    Q238
    AB - as you need to prevent 50% split.
  • Yannaing
    Yannaing Member
    Dec 31, 2015
    what answer i should choice , cc answer and uper answer are not same. Someone help me because tommorow i am going to take exam :)
