Relecloud Case Study
Discussion in '70-246' started by metro, Jan 10, 2016.
  1. metro
    metro Well-Known Member
    Supplier Contributor Member
    228
    Existing Environment
    Relecloud is a financial company located in Seattle.
    The company has the following main departments.
    • Marketing
    • Research
    • Audit
    The network contains a single-domain Active Directory forest named Relecloud.com. Relecloud has a Microsoft Azure subscription.
    System Center Environment
    Relecloud deploys infrastructure servers that host the following System Center 2012 R2 products.
    • Orchestrator
    • Service Manager
    • Operations Manager
    • Virtual Machine Manager (VMM)
    All the Hyper-V hosts are managed by using VMM.
    The operations Manager agent is deployed only to servers from the marketing department. There is an Operations Manager monitor named Monitor1 that applies to the Windows Operating System class.
    Relecloud uses Service Manager to track the service level objective (SLO) of its IT organization. Currently, SLOs calculate the duration of an incident by using the hour the incident is resolved.
    Service Manager is configured to have an email notification channel.
    Network and server infrastructure
    The main office has 11 Servers configured as shown in the following table.
    [​IMG]
    Server4 is configured to run explicit network discovery for 200 network devices. The inventory of the network devices is incomplete. The inventory contains a hub named Device1 and a switch named Device2.
    Server6, Server7 and Server8 are in the marketing department.
    The servers in each department run the operating systems shown in the following table.
    [​IMG]
    Server8 hosts a .NET application named APP1.
    You have an application named App2. App2 is a two-tier application that is deployed by using a VMM Service template named ServiceTemplate1. Both the tiers in ServiceTemplate1 are based on a virtual mavhine template named VMTemplate1.
    End of day processing for several line-of-Business (LOB) Applications is implemented by using custom Orchestrator runbooks in the on-premises environment. The processing typically takes hours.
    Users Problems
    Users Report that end-of-day processing frequently fails due to the hardware limitation of the runbook servers.
    When users request a virtual machine, the virtual machine is provisioned manually by an administrator. This process can take several weeks.
    There are many Service Manager Incidents that are resolved but remain open.
    Planned Changes.
    Relecloud plans to automate the provisioning of the virtual machines by using Service Manager Self-Services Portal.
    Technical Requirements
    Releclound must meet the following general technical requirements.
    • Minimize administration effort.
    • Use the principle of least privilege.
    Relecloud must meet the following Monitoring and reporting requirements.
    • Grand audit department permissions to view Service Manager reports.
    • Ensure that Monitor1 applies only to servers that run Windows Server 2012.
    • Monitor all of the Failover Clustering data from Cluster1 by using Operations Manager.
    • Configure and automatic email notification for the affected user upon the creation of an incident.
    • Modify the existing SLOs so that the duration of an incident is calculated by using the hour the incident is closed rather that resolved.
    • Monitor the resource utilization of VMM virtual machines, including average usage and total or maximum values for virtual machine processors, memory and disk space.
    Relecloud identifies, several virtual machine settings, that must be modified in the original version of ServiceTemplate1
    #1 metro, Jan 10, 2016
  2. metro
    228
    Question1
    You need to implement end-of day processing for Relecloud.
    What should you include in the implementation?
    A) In the Azure subscription, configure an Azure Batch compute job.
    B) On Server1, install the Integration Pack for Windows Azure.
    C) In the Azure subscription, create a high performance computing (HPC) cluster.
    D) On Server1, install Service Management Automation
    #2 metro, Jan 10, 2016
  3. metro
    228
    Question2
    You need to implement Workflow1.
    Which four actions should you perform on Server2 in sequence? To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.
    [​IMG]
    1) Run the Service Manager Authoring Tool;
    2)Run New-SCSMManagementPackBundle;
    3)Copy the assembly files to SM folder;
    4)From SM import a management pack
    #3 metro, Jan 10, 2016
  4. metro
    228
    Question 3
    You need to modify the criteria SLOs.
    Which Service Level Management setting should you modify from the Service Manager console?
    A) Metric
    B) Incident Settings
    C) Service Level Objectives
    D) Calendar
    #4 metro, Jan 10, 2016
  5. metro
    228
    Question 4
    You need to identify which systems you will be able to view by using Network vicinity dashboard once all of the network devices are discovered.
    Which three systems should you identify?
    Each correct answer presents part of the solution.
    A) Device1
    B) Device2
    C) the audit department servers
    D) the research department servers
    E) the marketing department servers
    #5 metro, Jan 10, 2016
  6. metro
    228
    Question5
    You need to ensure that users can self provision virtual machines.
    To which object should you assign permissions?
    A) a runbook
    B) a catalog group that contains request offerings
    C) a service catalog
    D) a task
    #6 metro, Jan 10, 2016
  7. metro
    228
    Question6
    You need to perform IAAS on demand backup of server2 with most resent files to azure backup
    A) create Incremental backup then create a restore point
    B) create express full backup then create a restore point
    C) Create a restore point then create Only-Synchronization
    D) Schedule a daily backup then create a restore point
    #7 metro, Jan 10, 2016
  8. metro
    228
    Question7
    App1 is an .NET application
    you need to recommend monitoring of APP1
    A) You use the .NET Application Performance Monitoring Template, available through the Authoring workspace of the Operations console, to configure Application Performance Monitoring
    B) Install web application monitor
    C) From Operations Manager Configure web application monitor
    D) web transaction monitor
    #8 metro, Jan 10, 2016
  9. metro
    228
    Question8
    [​IMG]
    The file server monitored by operations manager on the perimeter network
    you install Operations Manager managements packs on the Orchestrator server2
    What should you do next on Server2?
    A) Install Operations Manager Web console on Orchestrator
    B) Create the run books
    C) Install operations Manager Management gateway server on Orchesttrator.
    D) Register integration packs
    #9 metro, Jan 10, 2016
  10. Doyle
    Doyle Member
    Dec 5, 2015
    27
    @Metro, your attachments are unreachable but here are my answers:
    Q1 – А (Not B Integration Pack for Windows Azure enables you to automate Windows Azure operations related to certificates, deployments, cloud services, storage, and virtual machines
    Q2 – Run the Service Manager Authoring Tool; Run New-SCSMManagementPackBundle; Copy the assembly files to SM folder; From SM import a management pack
    Q3 – A
    Q4 – B,C,E (HUB ‘s have not MAC address, UNIX and LINUX host are not appear in Victinity Dashboard
    Q5 – A (runbook)
    Q6 – C (Create RECOVERY (not restore) point after synchronization or Create recovery point – Only synchronization are possible options to have resent online recovery points on Azure)
    Q7 – A
    Q8 – C (It is unclear how servers are placed but I assume that SCOM is in in Subnet1, SCHORCH and File Server are in Subnet2. In this case it seems that SCOM Gateway is only option if Server2 is Orchestrator here.)
  11. metro
    228
    Thanks Doyle,
    I have updated my posts with your answers
    Also the images are now fixed
  12. Doyle
    Doyle Member
    Dec 5, 2015
    27
    Question8
    [​IMG]
    Now it I am totally confused - where is this Orchestrator !?
    Nevertheless I am going tomorrow to take this exam and I should aware for this particular question.
  • Doyle
    Doyle Member
    Dec 5, 2015
    27
    Question5
    A) a runbook
    D) a task
    One correction here should be B - Catalog item groups in System Center 2012 – Service Manager are lists of catalog items that are used to secure the service catalog and provide access to users, based on membership in a corresponding Service Manager user role
  • Archie Praed
    Archie Praed Member
    Mar 28, 2016
    120
    Hello,I just got some new questions online, someone said they are "new"....
    70-246 New Questions:
    70-247 New Questions:
    You can have a look....
  • Baron
    Baron Member
    Jun 10, 2016
    Hello guys, can anyone send me complete dumps for 70-246 and 247
    , thanks
    this two Pdfs are the same Questions you can find in 70-246 - CC - Metro_Feb_2016.pdf so NO new Question in there.
  • ciscozel
    ciscozel Supplier
    Supplier Member
    73
    new questions on relecloud
    you need to need to ensure that you can monitor the servers in the rearch department
    a run the setup wizard
    b configure agent less monitoring
    c run the rpm utility
    D perform a push installation
  • ciscozel
    ciscozel Supplier
    Supplier Member
    73
    I think b ?
  • metro
    228
    You need to implement network discovery and monitoring for Relecloud.
    What should you do? To Answer, select the appropriate options in the answer area
  • jackpip
    jackpip Member
    Jan 10, 2016
    I think b ?
    I think the first answer is correct, only that it is wrong to the formula (no setup but discovery)
    Infact the operation manager use a discovery wizard for install and manage a Unix system.
    Read the article below:
  • jackpip
    jackpip Member
    Jan 10, 2016
    The answer is extrapolated from "Server4 is configured to run explicit network discovery for 200 network devices":
    Run Network device discovery on: Server 4
    Run Network device Monitoring on: Server 5
    Set the Discovery method to: Explit
