rommakin
Hi this is rooma from Holland and I would like to tell you that I passed my exam with the use of pass4surekey 70-765 dumps. I got same questions in my exam that I prepared from PDF. I will recommend you this website to all my friends for certification exams. https://www.pass4surekey.com/exam/70-765.html
jayakumar12345
Hi friends ,
I have some new questions in the exam time,
some what i remember the questions, i need answer for this questions please check and answer below questions,
1.you plan to migrate a Microsoft sql server instance between physical servers.
you must migrate the metadata associated with the database instance.
you need to ensure that the new instance retains the existing jobs and alerts.
solutions : you restore the service master key.
does the solution meet the goal?
A ) Yes
B) No
2. you plan to migrate a Microsoft sql server instance between physical servers.
solutions : you restore the master database.
A ) Yes
B) No
jayakumar12345
3. you plan to migrate a Microsoft sql server instance between physical servers.
solutions : you restore the model database.
A ) Yes
B) No
4. you deploy a new Microsoft azure sql database instance to support a varity of mobile application and public websites. You configure geo-replication with regions in Brazil and Japan.
You need to implement real-time encryption of the database and all backups.
Solution : you enable Dynamic Data Masking on the primary replica.
A ) Yes
B) No
5. you deploy a new Microsoft azure sql database instance to support a varity of mobile application and public websites. You configure geo-replication with regions in Brazil and Japan.
Solution : you enable Transparent Data Encryption (TDE) on the primary instance.
A ) Yes
B) No
jayakumar12345
4. you have a database named DB1 that contains a table named Table1. Tanlbe1 has a non-clustered index named index1.
You discover that index1 is corrupt.
You need to repair index1.
Which statement should you execute?
A. DBCC CHECKDB (‘db1’, REPAIR_FAST)
B. ALTER INDEX indx1 ON table1 REBUILD WITH (ONLINE-ON)
C. ALTER INDEX index1 ON table1 REORGANIZE
D. DBCC CHECKDB (‘db1’, DATA_PURITY)
5. you have a database named DB1 AND APPLICATION NAMED App1. App1 queries DB1.
You discover that a non-clustered index in DB1 is corrupt.
You need to repair the index. App1 must be able to query DB1 while the index is being repaired.
A. Run CHECKDB REPAIR DATABASE and specify the REPAIR_REBUILD parameter.
B. Restore DB1 from a backup.
C. Run CHECKDB REPAIR DATABASE and specify the ALLOW_DATA_LOSS parameter.
D. Drop and recreate the index.
6. you have Microsoft SQL server on a Microsoft Azure virtual machine. The virtual machine has 200 GB of data.
User report a slow response time when quering the database.
You need to identify whether the storage subsystem causes the performance issue.
Which performance monitor counter should you view?
A. Data sec/Write
B. Avg.disk Read Queue Length
C. % Disk Read Time
D. Disk sec/Read
jayakumar12345
6. you deploy a new Microsoft azure sql database instance to support a varity of mobile application and
Solution : you password protect all azure SQL backups and enable azure active directory authentication
for all azure SQL server instances.
A ) Yes
B) No
7. You manage a Microsoft SQL Server environment with several databases.
You need to ensure that queries use statistical data and do not initialize values for local variables.
Solution: you set the value of the MAXDOP parameter to 2.
A) Yes
B) No
8. You have Microsoft SQL Server on a Microsoft Azure virtual machine that has a database named DB1.
You discover that DB1 experiences WRITE_LOG waits that are longer than 50 ms.
You need to reduce the WRITE_LOG wait time.
Solution: Add additional log files to DB1.
A) Yes
B) No
jayakumar12345
Settings value
VM size D3
Storage Location Drive E
Storage type Standard
Tempdb location Drive C
The workload on this instance has of the tembdb load.
You need to maximize the performance of the tempdb database.
Solution : you use a D- Series VM and store the tempdb database on drive D.
A) Yes
B) No
10.
Settings value
VM size D3
Solution : you use an AB compute-intensive instance and store the tempdb database in Standard sorage.
A) Yes
B) No
11. Settings value
VM size D3
Solution : you use a GS- Series VM and store the tempdb database on attached Premium storage..
A) Yes
B) No
jayakumar12345
12. you have Microsoft SQL Server on a Microsoft azure virtual machine that has 12 databases. All
database files are in the same Azure Blob storage account.
You need to receive an email notification if I/O operations to the database files exceed 800 MB/s for
more than five minutes.
Solution: you run the Get-counter cmdlet and specify the –counter ‘\physicaldisk:disk Transfers/sec’
parameter.
A) Yes
B) No
13. you have Microsoft SQL Server on a Microsoft azure virtual machine that has 12 databases. All
Solution: you run the Get-counter cmdlet and specify the –counter ‘\physicaldisk:disk write/sec’
parameter.
A) Yes
B) No
14. you have Microsoft SQL Server on a Microsoft azure virtual machine that has 12 databases. All
Solution: you run the Add-AzureRmMetricAlertRule cmdlet and specify the –MetricName ‘Network
Out’ parameter.
A) Yes
B) No
jayakumar12345
15. you plan to migrate a Microsoft sql server instance between physical servers.
solutions : you restore the msdb database.
A ) Yes
B) No
16. you use a Microsoft Azure SQL database as a data warehouse. The database is in the Standard
service tier and has 400 elastic database throughput units (eDTUs).
You load data to the database by using Azure Data Factory.
You need to reduce the amount of time it takes to load the data.
Solution: you move the database to a premium database pool that has 125 eDTUs.
A ) Yes
B) No
17. . you use a Microsoft Azure SQL database as a data warehouse. The database is in the Standard
Solution: you move the database to a basic database pool that has 1,600 eDTUs.
A ) Yes
B) No
jayakumar12345
18. . you use a Microsoft Azure SQL database as a data warehouse. The database is in the Standard
Solution: you move the database to a Standard database pool that has 800 eDTUs.
A ) Yes
B) No
19. You are tuning the performance of a virtual machines that hosts a Microsoft SQL Server instance.
The virtual machine originally had four CPU cores and now has 32 CPU cores.
The SQL Server instance uses the default settings and has an OLTP database named db1. The largest
table in db1 is a key value store table named table1.
Several reports use the PIVOT statement and access more than 100 million rows in table1. You discover
that when the reports run, there are PAGELATCH_IO waits on PFS pages 2:1:1, 2:2:1, 2:3:1, and 2:4:1
within the tempdb database.
You need to prevent the PAGELATCH_IO waits from occurring.
Solution: You rewrite the queries to use aggregates instead of PIVOT statements.
A ) Yes
B) No
20. you use a Microsoft Azure SQL database as a data warehouse. The database is in the Standard
Solution: you move the database to a premium database that has 125 eDTUs.
A ) Yes
B) No
21. you deploy a new Microsoft azure sql database instance to support a varity of mobile application and
Solution : you use the always Encrypted wizard to encrypt all possible for the tables in the primary
instance.
A ) Yes
B) No
jayakumar12345
22. You are migrating an on-premises Microsoft SQL Server instance to SQL Server on a Microsoft Azure
virtual machine. The instance has 30 databased that consume a total of 2 TB of disk space. The instance
sustains more than 30,000 transactions per second.
You need to provision storage for the virtual machine. The storage must be able to support the same
load as the on-premises deployment.
Solution: you use drive D on the virtual machine to store the database files.
A ) Yes
B) No
23. Your company plans to use Microsoft Azure Resource Manager templates for all future deployments
of SQL Server on Azure virtual machines.
You need to create the templates.
Solution: You use Visual Studio to create a XML template that defines the deployment and configuration
settings for the SQL Server environment.
A ) Yes
B) No
Sharon Smith
All questions have from that Examsout.com and Verified by Experts 3V0-624 dumps, valid enough for passing now!
And Few days update
athos
A ) Yes
B) No
A ) Yes
B) No
A ) Yes
B) No
ArturWI
The new 70-765 dumps (July/2018 Updated) now are available, here are part of 70-765 exam questions (FYI):
NEW QUESTION 171
You deploy a new Microsoft Azure SQL database instance to support a variety of mobile application and public websites. You configure geo-replication with regions in Brazil and Japan. You need to implement real-time encryption of the database and all backups.
Solution: You enable Transparent Data Encryption (TDE) on the primary instance.
NEW QUESTION 172
Solution: You password protect all azure SQL backups and enable azure active directory authentication for all azure SQL server instances.
NEW QUESTION 173
Solution: You use the always Encrypted wizard to encrypt all possible for the tables in the primary instance.
NEW QUESTION 174
You manage a Microsoft SQL Server environment with several databases. You need to ensure that queries use statistical data and do not initialize values for local variables.
NEW QUESTION 175
You have Microsoft SQL Server on a Microsoft Azure virtual machine that has a database named DB1. You discover that DB1 experiences WRITE_LOG waits that are longer than 50 ms. You need to reduce the WRITE_LOG wait time.
This problem is related to the disk response time, not to the number of log files.
NEW QUESTION 176
Settings Value
VM size D3
The workload on this instance has of the tembdb load. You need to maximize the performance of the tempdb database.
Solution: You use a D-Series VM and store the tempdb database on drive D.
NEW QUESTION 177
You have Microsoft SQL Server on a Microsoft azure virtual machine that has 12 databases. All database files are in the same Azure Blob storage account. You need to receive an email notification if I/O operations to the database files exceed 800 MB/s for more than five minutes.
Solution: You run the Get-Counter cmdlet and specify the Counter \physicaldisk:disk transfers/sec' parameter.
NEW QUESTION 178
\physicaldisk:disk write/sec' parameter.
NEW QUESTION 179
Solution: You run the Add-AzureRmMetricAlertRule cmdlet and specify the MetricName Network Out' parameter.
NEW QUESTION 180
You use a Microsoft Azure SQL database as a data warehouse. The database is in the Standard service tier and has 400 elastic database throughput units (eDTUs). You load data to the database by using Azure Data Factory. You need to reduce the amount of time it takes to load the data.
Solution: You move the database to a Premium database pool that has 125 eDTUs.
We need at least 400 eDTUs.
NEW QUESTION 181
Solution: You move the database to a Basic database pool that has 1,600 eDTUs.
We need the use of a Standard database pool.
NEW QUESTION 182
Solution: You move the database to a Standard database pool that has 800 eDTUs.
We need at least 400 eDTUs and the use of a Standard database pool.
NEW QUESTION 183
You are tuning the performance of a virtual machines that hosts a Microsoft SQL Server instance. The virtual machine originally had four CPU cores and now has 32 CPU cores. The SQL Server instance uses the default settings and has an OLTP database named db1. The largest table in db1 is a key value store table named table1. Several reports use the PIVOT statement and access more than 100 million rows in table1. You discover that when the reports run, there are PAGELATCH_IO waits on PFS pages 2:1:1, 2:2:1, 2:3:1, and 2:4:1 within the tempdb database. You need to prevent the PAGELATCH_IO waits from occurring.
Instead you can add more files to the database.
NEW QUESTION 184
You are migrating an on-premises Microsoft SQL Server instance to SQL Server on a Microsoft Azure virtual machine. The instance has 30 databased that consume a total of 2 TB of disk space. The instance sustains more than 30,000 transactions per second. You need to provision storage for the virtual machine. The storage must be able to support the same load as the on-premises deployment.
Solution: You use drive D on the virtual machine to store the database files.
The D drive should only be used for temporary data.
NEW QUESTION 185
You have a database named DB1 that contains a table named Table1. Table1 has a non-clustered index named index1. You discover that index1 is corrupt. You need to repair index1. Which statement should you execute?
A. DBCC CHECKDB (
db1', REPAIR_FAST)
B. ALTER INDEX index1 ON table1 REBUILD WITH (ONLINE-ON)
D. DBCC CHECKDB (`db1', DATA_PURITY)
NEW QUESTION 186
NEW QUESTION 190
Database DB1 must use two CPU cores. Queries that were running on database DB2 prior to migration do not complete. You need to configure the databases. In the table below, identify the parameter that must be configured for each databases. Select one option for DB1, and one option for DB2. Select one option for each column.
NEW QUESTION 191
You have an on-premises database that runs several maintenance jobs. You move the database to a Microsoft Azure SQL database. You need to ensure that the maintenance jobs on indexes continue to run after the move. In which order should you perform the actions? (To answer, move all actions from the list of actions to the answer area and arrange them in the correct order.)
NEW QUESTION 192
Download more NEW Pass Leader 70-765 PDF dumps from Google Drive here:
https://drive.google.com/open?id=0B-ob6L_QjGLpZHlHSG5KM09xUms
Read the newest Pass Leader 70-765 exam questions from this Blog:
http://www.microsoftbraindumps.com/?s=70-765
Friso Bhagwandin
Would you like to share the full version of premium forbiden 70-765 dumps VCE and PDF???
Zaixkingg
Thanks "rommakin", this dump is valid. I only pass due to your shared practice material in your post.Thanks once again God bless you.
ArturWI
The new 70-765 dumps (Mar/2019 Updated) now are available, here are part of 70-765 exam questions (FYI):
NEW QUESTION 194
A company has an on-premises Microsoft SQL Server 2017 infrastructure. The storage area network (SAN) that supports the SQL infrastructure has reached maximum capacity. You need to recommend a solution to reduce on-premises storage use without changing the application. What should you do?
A. Configure an Express Route connection to Microsoft Azure.
B. Configure a Microsoft Azure Key Vault.
C. Configure geo-replication on the SAN.
D. Configure SQL Server Stretch Database in Microsoft Azure.
NEW QUESTION 195
A company runs Microsoft SQL Server 2017 in an on-premises environment. The databases are memory-optimized. An integrity check of a database has failed. You need to ensure that the data is healthy and passes an integrity check. What should you do?
A. Run the CHECKTABLE Transact-SQL statement.
B. Clear the buffer of the database.
C. Restore from a verified backup.
D. Run the CLEANTABLE Transact-SQL statement.
NEW QUESTION 196
You have an on-premises SQL Server database named DB1 that contains a table named TB1. TB1 is stretched to Microsoft Azure. A catastrophic hardware failure occurs on the on-premises SQL server. You deploy a new on-premises server and restore all databases to the new server. You need to resume Stretch Database operations to Azure. Which statements should you execute?
NEW QUESTION 197
You are developing customized Microsoft Azure Resource Group templates to automate the process of deploying Microsoft SQL Server in Azure to enforce consistency during future deployments. You need to deploy the customized templates to the Azure environment and to external endpoints. Which resource value should you populate?
A. properties
B. name
C. resources
D. dbType
E. apiVersion
NEW QUESTION 198
You have just completed a new Microsoft SQL Server installation. You need to configure a new SQL Server Agent alert to send an email to the DBA team for severity 20 errors. Which three actions should you perform? Each correct answer presents part of the solution. (Choose three.)
A. Set up SQL Mail.
B. Define an operator.
C. Configure a credential object.
D. Define the alert settings.
E. Configure a proxy.
F. Set up an External Events collector.
G. Set up Database Mail.
Answer: BDG
NEW QUESTION 199
You plan to enable Stretch Database for a table named Table1. You need to configure Table1 to move the data to Microsoft Azure. The data must be moved at a later time. How should you complete the statement? (To answer, drag the appropriate values to the correct targets. Each value may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.)
NEW QUESTION 200
You have a Microsoft Azure SQL Database server named server1-contoso.database.windows.net in a resource group named RG1. You need to create an elastic pool. How should you complete the script? (To answer, select the appropriate options in the answer area.)
NEW QUESTION 201
Your company has many Microsoft SQL Server instances hosted in a data center. You also manage five Microsoft Azure SQL Database instances that are hosted on a single server in Azure. You need to minimize costs associated with Azure resources while maintaining the current performance levels of each Azure SQL Database instance. Which three actions should you perform in sequence? (To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.)
NEW QUESTION 202
Your company has several Microsoft Azure SQL Database instances used within an elastic pool. You need to obtain a list of databases in the pool. How should you complete the commands? (To answer, drag the appropriate segments to the correct targets. Each segment may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.)
NEW QUESTION 203
A company uses several Microsoft Azure elastic pools with Azure SQL Database instances. You have two pools named Pool1 and Pool2. Pool2 is near maximum capacity and cannot accommodate the database move. You need to move the database from Pool1 to Pool2. Which PowerShell cmdlets should you run? (To answer, select the appropriate options in the answer area.)
NEW QUESTION 204
A company has an on-premises Microsoft SQL Server environment with a SQL Server named SQL01. You need to create a local sysadmin account on SQL01 NAMED Admin1. How should you complete the Transact-SQL statements? (To answer, select the appropriate Transact-SQL statements in the answer area.)
NEW QUESTION 205
You have a Microsoft SQL Server instance which hosts all of your corporate databases. A database named Sales stores information about customers and their contact information. You use the following processes for backing up the database:
  • All databases are configured for full recovery model.
  • Full backups are performed every morning at 2:00 AM.
  • Log backups are performed every hour starting at 9:00 AM.
At 9:35 AM, a member of the sales team mistakenly updates all customer records. You need to recover the database to a stable state and recover as much data as possible without recovering the changes that the sales team member made. Which four actions should you perform in sequence? (To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.)
NEW QUESTION 206
ArturWI
The new SQL Databases 70-765 dumps (Mar/2020 Updated) now are available, here are part of 70-765 exam questions (FYI):
NEW QUESTION 251
You plan to migrate on-premises Microsoft SQL Server databases to SQL Server on a Microsoft Azure virtual machine. A full back up of the databases is 3 TB. The corporate network has a 1.5 MB/sec Internet connection. You need to move the backups to Azure to ensure that you can restore the databases to the Azure virtual machine as quickly as possible. What should you do?
A. Use SQL Server Backup to URL.
B. Run azcopy.exe and specify the /SetContentType parameter.
C. Create an availability group that is configured for automatic seeding.
D. Run robocopy.exe and specify the /mir parameter.
E. Use the Azure Import/Export service.
Azure Import/Export service is used to securely import large amounts of data to Azure Blob storage and Azure Files by shipping disk drives to an Azure datacenter. This service can also be used to transfer data from Azure Blob storage to disk drives and ship to your on-premises sites. Data from one or more disk drives can be imported either to Azure Blob storage or Azure Files.
NEW QUESTION 252
You have a single-server on-premises Microsoft SQL Server deployment. You must migrate the environment to an Azure virtual machine (VM). You must minimize costs while maintaining the same level of performance as the on-premises SQL environment. You need to evaluate the number and types of read/write operations for the existing deployment. Which tool should you use?
A. SQL Disk Usage Standard Report
B. Database Engine Tuning Advisor
C. SQLIOSim
D. SQL Profiler trace using TSQL template
NEW QUESTION 253
A company plans to run Microsoft SQL Server on Linux-based servers. You need to ensure that performance tuning settings are automatically configured during installation. Which Linux platform should you recommend?
A. Kali Linux
B. RHEL
C. SUSE
D. Ubuntu Server
NEW QUESTION 254
You have deployed several GS-series virtual machines (VMs) in Microsoft Azure. You plan to deploy Microsoft SQL Server in an Always On Availability Group. The new environment has the following storage requirements:
  • Two terabytes (TB) of total storage capacity
  • 5,000 total IOPS for pooled storage
You need to add the storage to all VMs while minimizing the number of disks per VM. Which storage option should you use?
A. Premium P10 disk storage
B. Premium P20 disk storage
C. Premium P30 disk storage
D. Standard locally redundant disk storage
E. Standard geo-redundant disk storage
F. Standard zone redundant blob storage
G. Standard locally redundant blob storage
H. Standard geo-redundant blob storage
NEW QUESTION 255
A. SQL Profiler trace using Tuning template
B. DiskSpd
C. Import/Export wizard
D. SQL Server Logs
The DiskSpd utility is a feature-rich and versatile storage testing tool that is ideal for testing the storage subsystem.
NEW QUESTION 256
You have three Microsoft SQL Server instances. Each instance is deployed to a separate physical server. You must install a new SQL Server instance for the marketing team. All instances must have the same configuration. You need to create an unattended answer file to deploy the marketing SQL instance. What should you do?
A. Create an autounattend.xml file.
B. Cope the ConfigurationFile.ini from one of the other servers.
C. Cope the setup.exe.config file from one of the other servers.
D. Copy the rlauncher.log file from one of the other servers.
NEW QUESTION 257
Your company plans to use Microsoft Azure Resource Manager templates for all future deployments of SQL Server on Azure virtual machines. You need to create the templates.
Solution: You use Visual Studio to create a XML template that defines the deployment and configuration settings for the SQL Server environment.
Azure Resource Manager template consists of JSON, and expressions that you can use to construct values for your deployment. A good JSON editor, not a Resource Group template, can simplify the task of creating templates.
NEW QUESTION 258
You plan to create an AlwaysOn availability group that will have two replicas in Microsoft Azure and two on-premises replicas. You need to ensure that a replica in Azure is always available. Which cmdlet should you run before you deploy the virtual machines?
A. New-AzureRmAvailabilitySet
B. New-AzureRmLoadBalancer
C. New-AzureRmSqlDatabaseSecondary
D. New-AzureRmSqlElasticPool
E. New-AzureRmVM
F. New-AzureRmSqlServer
G. New-AzureRmSqlDatabaseCopy
H. New-AzureRmSqlServerCommunicationLink
NEW QUESTION 259
You deploy a Microsoft SQL Server instance to support a new application. The application uses the tempdb database to maintain session state data. Users report performance issues with the application. You observe performance problems immediately and begin troubleshooting. You observe numerous instances of the page PAGELATCH_UP and PAGELATCH_EX wait events in the logs for the server. The resource description for the wait is 2:1:1. You need to resolve the performance problem. What should you do?
A. Increase the number of tempdb log files.
B. Use the Read Committed Snapshot Isolation mode.
C. Replace temporary tables with table-valued functions.
D. Increase the value of the Cost Threshold for Parallelism setting.
E. Increase the size of the tempdb.
F. Increase the value of the MAXDOP setting.
PAGELATCH_EX occurs when a task is waiting on a latch for a buffer that is not in an I/O request. The latch request is in Exclusive mode. PAGELATCH_UP occurs when a task is waiting on a latch for a buffer that is not in an I/O request. The latch request is in Update mode.
NEW QUESTION 260
A company plans to use a Microsoft Azure SQL Database instance to manage sensitive data. The solution must allow data to be decrypted while in use but encrypted while at rest. You need to ensure that the columns are protected. What should you use?
A. static data masking
B. persistent data masking
C. Transparent Data Encryption
D. Recovery Services vault
Transparent data encryption (TDE) encrypts your databases, associated backups, and transaction log files at rest without requiring changes to your applications.
NEW QUESTION 261
A Microsoft SQL Server instance has a database named Employees. The database contains information about employees including their salary. You must create a custom system message as an alert when an error is raised. You need to create the custom message in the sys.messages table. Which argument in sp_addmessage should you configure?
A. @with_log
B. @lang
C. @severity
D. @replace
NEW QUESTION 262
You have Microsoft SQL Server on a Microsoft Azure Virtual machine. The virtual machine has a database named DB1. You need to identify the fragmentation percentage for the indexes of DB1. Which dynamic management view should you query?
A. sys.dm_db_index_operational_stats
B. sys.dm_db_index_physical_stats
C. sys.dm_db_xtp_hash_index_stats
D. sys.dm_db_index_usage_stats
NEW QUESTION 263
You have a database named DB1 that is 3 TB. DB1 contains a fact table that is 1.2 TB. You load 200 GB of new data to the fact table from a line-of-business application. Users of DB1 notice that reports render more slowly after you loaded the data. What are two possible causes of the performance issue? (Each correct answer presents a complete solution. Choose two.)
A. transaction log growth
B. out-of-date statistics
C. page corruption
D. index fragmentation
NEW QUESTION 264
A company hosts a default installation of Microsoft SQL Server 2017 on a Linux-based server. You observe that the performance of the server has degraded. Process for allocating tables show high latency. You need to recommend a solution to improve performance when allocating tables. What should you recommend?
A. Configure additional tempdb data files.
B. Reinstall SQL Server on Linux.
C. Set a memory limit for the SQL server.
D. Increase the Virtual Address Space limit.
NEW QUESTION 265
A company has an infrastructure that runs Microsoft SQL Server 2017 in Azure. You need to ensure that validation is performed on a memory-optimized Linux system. Which Transact-SQL statement should you run?
A. DBCC CHECKALLOC
B. DBCC CHECKSUM
C. DBCC CHECKTABLE
D. DBCC CHECKATALOG
NEW QUESTION 266
Download more NEW Pass-Leader 70-765 PDF dumps from Google Drive here:
Read the newest Pass-Leader 70-765 exam questions from this Blog:
To pass Microsoft 70-765 exam is no more dream. Now Microsoft students don’t need to burn midnight all to pass Microsoft 70-765 exam. Just visit Exams4Sale and get material from Microsoft 70-765 Expert.Get 40% discount by using promocode E4S40%OFF. Exams4Sale offers more relevant and upto date material for Microsoft exam dumps so the material is 100% accurate that’s why I recommend you this site for your Microsoft 70-765 exam on the basic of above mentioned qualities. So light up your lamp of success by visiting the link below:
