Updated Citrix 1Y0-230??
Discussion in 'Networking' started by James Riccio, Jan 23, 2018.
  1. James Riccio
    James Riccio Member
    Jan 22, 2018
    The two dumps that I have (actual4test & Lead2Pass) are useless. Over 1/2 the questions are wrong.
    Anyone have an updated dump? Much appreciated.
    Cheers
  2. TheRo
    TheRo Member
    Jul 25, 2016
    Do you know if the questions are valid?
  3. James Riccio
    James Riccio Member
    Jan 22, 2018
    Right test questions, but about 60% are wrong. Failed the test with 50%
    Have a lab environment up & going through each question.
  4. zapatero
    zapatero Member
    Apr 16, 2018
    Any news on this exam ? I got an ete but seems too many answers are wrong
  5. Webj
    Webj Member
    Apr 3, 2018
    Anyone got actual4test? I only see passleader here.
  6. James Riccio
    James Riccio Member
    Jan 22, 2018
    Finally circling back to finish this cert. Trying to cleanup the wrong questions & will post an updated VCE
    Input on these would be great!
    1) Which three NetScaler features can a Citrix Administrator use for default syntax policies? (Choose three.)
    A. SSL
    B. Rewrite
    C. Integrated caching
    D. Protection
    E. Responder
    Answer: ACE
    Think it might be B,C & E SSL is both default & classic. Not sure the excludes it?
    2) Which mode does a Citrix Administrator need to configure in order to allow the NetScaler to forward any packets that are NOT destined for an IP address which is NOT configured on NetScaler?
    A. Layer 3
    B. USIP
    C. Layer 2
    D. MAC-based Forwarding
    Layer 3 is enabled by default. Layer 2 is required for packet forwarding.
    Cheers
    Alisson Henrique likes this.
  7. Alisson Henrique
    Jul 5, 2018
    Hello James, do You have a update Exam? Tks
  8. Koji47
    Koji47 Member
    Mar 12, 2018
    James did you get around to this?
    Only learning NS so can't provide input yet.
  • volvo132
    volvo132 Member
    Dec 21, 2015
    Hi I managed to correct most of the answers. for sure some of them are still incorrect. Here in Poland based on my dumps my colleague passed exam on 71%. he said that there were maybe 1-2 new questions that he does not remember and maybe a few was a bit more detailed.
    Lets together fix answers!
  • volvo132
    volvo132 Member
    Dec 21, 2015
    Updated file with much more proper answers. I passed with almost 90% last week.
    Steven Young and Oghuz like this.
  • Fernando Gomez
    Oct 27, 2018
    Hi
    I would like to know if you can facilitate the exam in a link to download it if you have it in PDF or VCE if possible please.
  • volvo132
    volvo132 Member
    Dec 21, 2015
    Unfortunately no. I used free software from vumingo to create .ete file. much easier to modify, etc.
  • Oghuz
    Oghuz Member
    Nov 6, 2018
    Thank you for sharing, volvo132. Will keep you guys posted if I find this material useful.
  • Steven Young
    Steven Young Member
    Nov 29, 2018
    Thank you Volvo. I appreciate your hard work going into this. A lot of the questions seems to ring true now with what I've learned on the Instructor led course this week, and isn't just confusing the life out of me like those other "Exam dumps" that are knocking about.
  • orionas
    orionas Member
    Dec 16, 2018
    Hi Volvo132 i found 2 question that i believe has wrong anwnser
    q38
    There is no such option x1 theme throught global setting
    q98
    The correct answer is basen on CTX114146 article
    Ensure that intermidiate cert is linked to the server certificate
    q12
    Are you sure that is not as correct anwser the Netscaler MAS?
  • Oghuz
    Oghuz Member
    Nov 6, 2018
    After study and research:
    q12
    HDX Insight is the best answer since it is asking for the tool and not the whole product. HDX Insight is part of Netscaler MAS.
    q38
    "There is no such option x1 theme through global setting" true. But there is x1 theme at NetScaler Gateway > Portal Themes so why create a custom one?
    I'm taking the exam this Friday. Wish me luck. :)
  • vyral4122
    vyral4122 Member
    Dec 27, 2018
    Hello Oghuz, did you pass?
  • Terry Chan
    Terry Chan Member
    Dec 31, 2018
    volvo132 set is still valid. Thanks
  • Jenifer VN
    Jenifer VN Member
    Feb 27, 2018
    266
    if you want to pass your exam on the first attempt, i will recommend you this website from where you get latest and actual exam preparation materials. i am sure after using their practice materials you will pass your exam on the first attempt.
  • Oghuz
    Oghuz Member
    Nov 6, 2018
    Nope. Sorry guys
