Updated CompTIA A+ 220-901 Exam Questions On August 28
Discussion in '220-801' started by killtest, Sep 7, 2018.
  1. killtest
    killtest Member
    May 2, 2018
    40
    Now you should pass CompTIA 220-901 and 220-902 exams for your CompTIA A+ certification. Killtest has updated CompTIA A+ 220-901 exam questions on August 28 to ensure you can get latest study materials for CompTIA A+ certification exam.
    Try updated 220-901 exam questions for testing:
    A technician needs to run a diagnostic DVD on a laptop running Windows 8.1. After setting the boot order in the UEFI BIOS to the internal DVD-RW drive, the laptop still boots into Windows. Which of the following settings needs to be adjusted in order for the laptop to boot from the DVD-RW drive?
    A. TPM
    B. Virtualization
    C. Secure boot
    D. UEFI BIOS password
    A technician connects a second monitor to a desktop. It is physically located to the right of the existing monitor, but the mouse pointer can only get to the second monitor by moving to the left edge of the screen of the first monitor. Which of following display settings needs to be adjusted to get the pointer to move with the physical placement of the monitor?
    A. Scaling
    B. Rotation
    C. Position
    D. Resolution
    Which of the following types of cables are MOST likely to be used to connect to an external hard drive? (Choose two.)
    A. Molex
    B. SPDIF
    C. eSATA
    D. HDMI
    E. USB 3.0
    F. CAT6e
    Answer: C,E
    A customer is building a high-end gaming PC and is seeking an appropriate power supply unit. Which of the following feature-sets of a power supply should be installed? (Select THREE).
    A. Mini-ITX form factor
    B. High number of connectors
    C. 24-pin main connector
    D. 20-pin main connector
    E. 350-450 watts of power
    F. Dual 12v rails
    Answer: B,C,F
    Which of the following is required during the installation of a digitizer?
    A. Must be connected to the Internet
    B. Must be cleaned
    C. Must have the latest software installed
    D. Must be calibrated
  2. Ronald Bergin
    Ronald Bergin Member
    Aug 11, 2018
    97
    Thanks for the Post it is Very Informative But I want to Share my Experience with you that i Pass my CompTIA A+ 220-901 Exam
    at first attempt by getting Best Exam Preparation Material Form :
    They Really were Amazing and I recommend you to Get Certification Exam from Dumpshq.
  3. bairstrowjhon
    bairstrowjhon Member
    Sep 24, 2018
    377
    148
    I really wanted to pass the Comp TIA 220-901 exam. I was looking for real Comp TIA 220-901 exam dumps pdf after practicing from Pass4surekey Comp TIA
    Questions Answers I got 97%.
  4. Eric Hamm
    Eric Hamm Member
    Monday
    55
    Prepared Your Self With New 220-901 PDF Questions with Free Updates Highly Recommended By CompTIA
    Yes, you can receive proper tips and except this we provide to all authentic and updated material, which is 100% real, actual and related to your CompTIA A+ Certification Exam exam. More than 20 thousand students have clear their exams to used our material.
    You can you 100% clear your 220-901 Certification without any fear with the refreshed
    given by DumpsStar, you can pass any CompTIA exams with no issue. DumpsStar have curated superb CompTIA 220-901 content for our clients and we give all the 220-901 pdf intend material you require to pass CompTIA A+ Certification Exam exam in the first attempt.
    We have various 220-901 Questions that will allow you to pass 220-901 exam rapidly. 220-901 dumps are trusted by thousands when searching for 220-901 exam dumps control for passing 220-901 test, at that point such as DumpsStar 220-901 dumps has got you secured. We have all that you require that will enable you to pass the 220-901 exams in a solitary endeavor. DumpsStar is Leader of Certifications gives substantial 220-901 PDF questions and checked answers that you will pass the exam in a friendless attempt.
    Copy & Paste This URL In Your Browser and Get Latest Questions: dumpsstar.com/220-901-pdf-dumps.html
    [​IMG]
    FEATURES OF DumpsStar
    USER FRIENDLY
    DumpsStar is working as a friendly, because we are sincere with our users. If user is satisfying from us, then ultimately we are satisfying otherwise we are in tension because we honor our customer so I give first prefer to user that he get success in exam.
    DISCOUNT FOR EVERY PURCHASE:
    We allow discount to all the students on every purchase dumps. This very special for our honorable customers that they purchase valid and factual material and get high marks in exam.
    FREE UPDATE FOR 3 MONTH
    If you are purchasing our exam pdf pack, then you will be able to receive regular free updates for the preparation material.
    SATISFACTORY:
    Customer satisfaction is the first priority of the DumpsStar and 100% money back guarantee, if you are fail and not satisfied our offer.
    • If you like and satisfy with answer so plz upvote this.
    • Comment if you have a question or something to share.
    Need to jump on
    Wish you all the very best.
