VCP6.5-DCV Certification 2V0-602 Study Materials
Discussion in 'VM Ware Questions & Answers' started by killtest, Aug 10, 2018.
  1. killtest
    killtest Member
    May 2, 2018
    40
    Just come to Killtest to get VCP6.5-DCV Certification 2V0-602 Study Materials. Have proven that Killtest 2V0-602 study materials contain real 2V0-602 exam questions and answers, which are the best exam preparation for passing 2V0-602 VSphere 6.5 Foundations Exam.
    What three shares are available when configuring a Resource Pool? (Choose three.)
    A. Custom
    B. Low
    C. Maximum
    D. Normal
    E. None
    Answer: A,B,D
    A vSphere Administrator notices that a virtual machine is performing poorly, and upon investigation has observed the following:
    What is the first step in troubleshooting this problem?
    A. Shut down the virtual machine and double the amount of vCPU and RAM assigned.
    B. Shut down the virtual machine and set the number of vCPU as high as possible.
    C. Migrate the virtual machine to an ESXi host with more resources available.
    D. Configure the virtual machine with CPU and Memory limits.
    Which of the following are valid iSCSI adapter types for vSphere? (Choose three.)
    A. Software
    B. Independent Hardware
    C. Converged Network Adapter
    D. Dependent Hardware
    E. iSCSI HBA
    Answer: A,B,D
    Which two choices would make a Virtual Machine compatible when enabling Fault Tolerance? (Choose two.)
    A. e1000e virtual network adapter
    B. 2 TB + VMDK
    C. 4 Virtual CPUs (vCPU)
    D. NIC passthrough
    Answer: A,C
    Get Full version of Killtest 2V0-602 study materials:
