Which Microsoft Azure Power Shell cmdlet should you use with each Power Shell command line?
metro
Supplier
Supplier
ou manage an Azure virtual machine (VM) named AppVM. The application hosted on
AppVM continuously writes small files to disk. Recently the usage of applications on AppVM
has increased greatly.
You need to improve disk performance on AppVM.
line? To answer, drag the appropriate Microsoft Azure Power Shell cmdlet to the correct
location in the Power Shell code. Each Power Shell cmdlet may be used once, more than
once, or not at all. You may need to drag the split bar between panes or scroll to view
content.
