You need to deploy several read-only DC in contoso by using pre-staged computer accou
Discussion in '70-410 Exam files' started by ciscozel, Dec 1, 2015.
  1. ciscozel
    ciscozel Supplier
    Supplier Member
    73
    Your directory contains one AD domain named contoso.com.The domain contains 10 DC that run WS2012R2. 8 DC are writable DC.
    You need to deploy several read-only DC in contoso by using pre-staged computer accounts.
    Which two tasks should you perform?Each correct answer presents part of solution.
    A: Run the Add-AddsReadOnlyDomainControlleraccount cmdlet.
    B:Create an authentication policy silo.
    C:Create an authentication policy.
    D:Run the Install-AddsDomainControler cmdlet.
    E:Run the adprep /rodcprep command
    F:Join the servers to contoso.com.
    It’s A and D
