Doubts - 70-533
rodsasilva38
Hello,
I can not understand the question below
QUESTION-1: You administer an Azure SQL Database that runs in the S0 service tier.
The database stored mission- critical data.
You must meet the following requirements:
- minimize costs associated with hosting the database in Azure
- minimize downtime in the event of an outage
- protect the database from unplanned events
A. Implement a secondary database in the paired region.
B. Ensure that a secondary databases are online and readable at all times.
C. Create a continuously replicated copy
D. Use backups in a geo-redundant Azure storage (GRS) locatio
Alexandrajhon
Hi friends, I pass 70-533 exam today Try 70-533 dumps PDF which are available on dumps4certs.com. Complete information is available on it regarding course 70-533 question & answers. Moreover there is less chances for failure in exam so it’s a suggestion to review the cisco 70-533 dumps PDF before starting exam. if you want good result just follow this link
http://www.dumps4certs.com/exam/70-533.html
That same questions are in following.
You administer an Azure virtual network named fabrikam VNet.
You need to deploy a virtual machine (VM) and ensure that it is a member of the fabrikam VNet virtual network.
A. Run the New-Azure VM Power Shell cmdlet.
B. Run the New-Azure Quick VM Power Shell cmdlet.
C. Run the New-Azure A fhnity Group Power Shell cmdlet.
D. Update fabrikam VNet's existing Availability Set.
Your company network has two physical locations configured in a geo-clustered environment. You create a Blob storage account in Azure that contains all the data
associated with your company.
You need to ensure that the data remains available in the event of a site outage.
Which storage option should you enable?
A. Locally redundant storage
B. Geo-redundant storage
C. Zone-redundant storage
D. Read-only geo-redundant storage
You administer an Azure Storage account with a blob container. You enable Storage account logging for read, write and delete requests.
You need to reduce the costs associated with storing the logs.
A. Execute Delete Blob requests over https.
B. Create an export job for your container.
C. Set up a retention policy.
D. Execute Delete Blob requests over http.
