Gabriel357
Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution that might meet the stated goals. Some question sets might have more than one correct solution, while others might not have a correct solution. After you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen.
You plan to create a Content Delivery Network (CDN) in Azure that meets the following requirements:
- Ensure that content can be preloaded into CDN endpoints.
- Accept client requests that use HTTP or HTTPS.
- Accept content from customized origin ports.
- Minimize costs per gigabyte (GB) delivered.
You need to create the CDN profile and endpoint.
Solution: You create a CDN profile by using Azure CDN Standard from Verizon SKU.
You configure the profile to use a storage account endpoint.
You plan to enable access to a blob storage account for external clients.
The access method must include an expiration time and clients should not be able to access other storage services.
You need to provide access to the storage account.
Solution: You regenerate the storage account keys.
Solution: You create a storage account shared access signature.
You plan to create virtual machines (VMs) that run Linux in an Azure subscription.
You need to ensure that passwords are disabled when you create the VM.
Solution: You specify a SSH private key when creating the VMs.
Solution: You specify a SSH public key when creating the VMs.
QUESTION 6
A company has virtual machines (VMs) that run in Azure. They plan to use Desired Stale Configuration (DSC) to manage the VM setting.
You need to programmatically prepare the VM 10 use DSC.
Which Azure PowerShell cmdlet should you run?
A. Set-AzureVMscExtention
B. Set-AzureVMcustomScripExtentiom
C. Set-AzureVMExtantion
D. Set-AzureVMSupportExtention
2018 Latest 70-533 Exam Dumps (PDF) Download
Complete PDF Link: http://bit.ly/70-533-Dumps-PDF
Alexandrajhon
Hi friends, I pass 70-533 exam today Try 70-533 dumps PDF which are available on dumps4certs.com. Complete information is available on it regarding course 70-533 question & answers. Moreover there is less chances for failure in exam so it’s a suggestion to review the cisco 70-533 dumps PDF before starting exam. if you want good result just follow this link
http://www.dumps4certs.com/exam/70-533.html
That same questions are in following.
You administer an Azure virtual network named fabrikam VNet.
You need to deploy a virtual machine (VM) and ensure that it is a member of the fabrikam VNet virtual network.
A. Run the New-Azure VM Power Shell cmdlet.
B. Run the New-Azure Quick VM Power Shell cmdlet.
C. Run the New-Azure A fhnity Group Power Shell cmdlet.
D. Update fabrikam VNet's existing Availability Set.
Your company network has two physical locations configured in a geo-clustered environment. You create a Blob storage account in Azure that contains all the data
associated with your company.
You need to ensure that the data remains available in the event of a site outage.
Which storage option should you enable?
A. Locally redundant storage
B. Geo-redundant storage
C. Zone-redundant storage
D. Read-only geo-redundant storage
You administer an Azure Storage account with a blob container. You enable Storage account logging for read, write and delete requests.
You need to reduce the costs associated with storing the logs.
A. Execute Delete Blob requests over https.
B. Create an export job for your container.
C. Set up a retention policy.
D. Execute Delete Blob requests over http.
