AaronCameron
The new 701-100 dumps (Mar/2019 Updated) now are available, here are part of 701-100 exam questions (FYI):
What happens when a merge conflict occurs in git? (Choose two.)
A. The conflicting files remain unchanged in the local repository.
B. Conflict markers are added to the files.
C. A new branch containing the remote changes is created.
D. The affected files are flagged as conflicting.
E. The newest version is placed in the local repository.
Which of the following commands lists the cookbooks available on a Chef server?
A. kitchen cookbook list
B. chef-client cookbook list
C. chef-server cookbook list
D. chef-solo cookbook list
E. knife cookbook list
Which of the following functions are provided by the Ansible apt module? (Choose two.)
A. Update an installed package to the latest version.
B. Update the list of available packages from configured repositories.
C. Re-compile an installed package from the source code.
D. Add the URL of a new repository to the package manager configuration.
E. Install a dpkg based Linux distribution on an empty target system.
Which of the following container names could have been assigned automatically by Docker?
A. docker-c00001
B. 2.0.17.172
C. container
D. c0023817
E. clever_ritchie
Which of the following tasks are completed by docker-compose down when it is used with additional parameters? (Choose two.)
A. Delete all volumes defined in the composer file.
B. Delete all containers defined in the composer file.
C. Delete all networks defined in the composer file.
D. Delete all images used in the composer file from the Docker nodes.
E. Delete all images built from the composer file from their registry.
Which section of the Prometheus configuration defines which nodes are monitored?
A. scrape_config
B. targets
C. rules
D. listener
E. nodes
Which sections can exist in a Logstash configuration file? (Choose three.)
A. output
B. filter
C. input
D. forward
E. generate
A service should be provided to arbitrary clients on the Internet using HTTPS. Any standard client on the Internet should be able to consume the service without further configuration. Which of the following approaches can be used to implement these requirements? (Choose three.)
A. Configure the web servers to not use a server certificate when serving HTTPS.
B. Generate a self-signed certificates during the deployment of each backend server.
C. Use a certificate issuing service to request certificates during each server deployment.
D. Use a load balancer that decrypts incoming requests and passes them on in plain HTTP.
E. Install a wildcard certificate and the respective private key on all the backend servers.
Answer: BCD
How does Vagrant run virtual machines?
A. Vagrant uses a vagrant-specific hypervisor called VagrantVM.
B. Vagrant has to be run within a running virtual machine which is not controlled by Vagrant.
C. Vagrant ships with an embedded version of VirtualBox.
D. Vagrant uses so-called provides which control external hypervisors such as VirtualBox.
E. Vagrant generates virtual machine images but does not provide a mechanism to run them.
Which of the following sections must exist in a Packer template?
A. images
B. provisioners
C. builders
D. variables
E. post-processsors
Which of the following elements are presents in a Vagrant box file? (Choose two.)
A. A Vagrant guest configuration file that is used to create instances of the box.
B. Configuration files for provisioners such as Ansible.
C. The installer for the Vagrant version which is required to run the box.
D. A metadata file describing the box and its requirements.
E. A base file system image in a format supported by the provider of the box.
What is tested by unit tests?
A. The syntactical correctness of the source code of a software component.
B. The formal validity of a service's external REST API.
C. The integration of multiple component of the same software.
D. The correctness of a specific function of a software component.
E. The throughput, load capacity and latency of a service.
NEW QUESTION 13
Download more NEW Pass Leader 701-100 PDF dumps from Google Drive here:
Read the newest Pass Leader 701-100 exam questions from this Blog:
