Sacriestory looking for 70-535 or 70-533 to Validate it
Sacriestory
Hey mates ..
I found a lot of garbage and scam on these post.
Sellers , don´t fuck..
[email protected]
Hey Sacriestory I'd like to say thank you a lot for your exam dumps 410-412 they really helped me alot and I managed to pass,
I have to say please share the 70-533 dump when you get one *please*.
Many thanks to you in advance,
Cheers.
Sacriestory
Cheers.
For sure... as always
Sacriestory
Cheers.
But I really need to look for this one, seems that has being updated recently and no body has tested . I would like fix it, but I cant get it. if you find it, send it to me and I will review it and test it
[email protected]
Great I will make a plan on getting this one, the one that I have is larger than 1 MB which is the maximum size for uploading on this forum.
tjoep
Have you checked the examcollection premium file? got 8 new questions a couple of weeks ago from the 325 questions in there. But some of them have wrong answers, there are even some double questions in there with different answers =/
btw, you 've got a point, i'm getting sick of the spammers over here.
[email protected]
Hi Sacriestory I hope you doing good, did you receive the 70-533 dumps i sent you via email?
Segee
Let us know if you get an updated one. Your 410-412 was amazing. Looking forward to anything you have. Thanks for all your help!
Alexandrajhon
Hi friends, I pass 70-533 exam today Try 70-533 dumps PDF which are available on dumps4certs.com. Complete information is available on it regarding course 70-533 question & answers. Moreover there is less chances for failure in exam so it’s a suggestion to review the cisco 70-533 dumps PDF before starting exam. if you want good result just follow this link
http://www.dumps4certs.com/exam/70-533.html
That same questions are in following.
You administer an Azure virtual network named fabrikam VNet.
You need to deploy a virtual machine (VM) and ensure that it is a member of the fabrikam VNet virtual network.
A. Run the New-Azure VM Power Shell cmdlet.
B. Run the New-Azure Quick VM Power Shell cmdlet.
C. Run the New-Azure A fhnity Group Power Shell cmdlet.
D. Update fabrikam VNet's existing Availability Set.
Your company network has two physical locations configured in a geo-clustered environment. You create a Blob storage account in Azure that contains all the data
associated with your company.
You need to ensure that the data remains available in the event of a site outage.
Which storage option should you enable?
A. Locally redundant storage
B. Geo-redundant storage
C. Zone-redundant storage
D. Read-only geo-redundant storage
You administer an Azure Storage account with a blob container. You enable Storage account logging for read, write and delete requests.
You need to reduce the costs associated with storing the logs.
A. Execute Delete Blob requests over https.
B. Create an export job for your container.
C. Set up a retention policy.
D. Execute Delete Blob requests over http.
Smile
I am planning to sit both exams before they expire end of this month, struggling to find the latest updates for 70-533 and 70-535.
No sellers please.
