Same Old question, but new choices
kennethgdavid
Hi, the question on dumps is the same, but on the actual exam, the choices are different.
Q. You are deploying an ASP.NET application to an Azure virtual machine (VM).
The application throws an exception when invalid data is entered.
When exceptions occur, an administrator must log on to the system to remove the bad data, and then restart the application.
You need to gather information about application crashes.
A. Collect network and web metrics.
B. Collect basic metrics.
C. Collect .NET metrics.
D. View the Windows event security logs.
the choices on the dumps are:
A. View the IIS logs.
B. View the Windows event system logs.
C. View the Windows event application logs.
D. Collect network and web metrics.
on the dumps, C is the answer. On the real exam, there is no event application logs.
rubenscr
And this case, what is the correct answer?
zzmflz
hello,
an information, I have learned from some of my colleagues who have carried out the exam this month that the questions are all new. Do you by any chance confirm me, and do you have any new material? thanks
rubenscr
hello,
Now I`m studying the dumps from https://www.examcollection.com/70-533.html (take the dumps more recently and with best opinions) and from https://drive.google.com/drive/folders/0B-ob6L_QjGLpfnV3MVl6X3pXOWw1Z3YtQUpJRVRiTkNkbGNFbVBNRXhjSkw3bWk1WHdYcW8
and in the next days I will buy the Premium dump from ExamCollection web. I will take the 70-533 in a couple weeks.
zzmflz
hello,
this material is great but I have noticed that there are new questions that you will not find anywhere.
good luck for your exam
ciccio
Hi guys any news?
Mgatneto
Anyone?
